Parking brake cable installation 1972 cutlass
Old August 8th, 2018, 01:35 PM
Chris
Oldssupreme's Avatar
Hi! Can anyone help with advice as to how to install my parking brake cables in my 1972 cutlass? I think I have everything as shown in the assembly manual but I can't get one side or the other to reach the connector with the brake drum cable. What am I doing wrong? Thanks!
Chris
Oldssupreme is offline
Old August 8th, 2018, 01:56 PM
frankr442's Avatar
Hard to tell without seeing the car. You may have the hooks in the wrong holes?
Did you have cables before or is this a new installation. You may have the wrong cables.
frankr442 is offline
Old August 8th, 2018, 02:08 PM
Chris
Frank hi. I'm using cables from a 71 supreme with the same setup as my 72. Column Auto 350 th350 etc. could the cables be different?
Old August 8th, 2018, 02:17 PM
Chris, the cables should be identical.
Start by hooking up the rear cables to the parking brake cables.
Now make sure you have the S hooks properly positioned and thread the cable through them and across to the adjuster.
You can adjust the tension or looseness of the cable by tightening up that assembly.
How much are you out on the connection?
Also make sure your e brake pedal in the car is fully up.
Allan R is offline
Old August 8th, 2018, 03:31 PM
Chris
Thank you Allen. I will try that tomorrow. I tried to connect the back first so maybe that's the problem. I was about an inch out at the drivers side with everything else connected and the adjustment all the way out. Am I correct that the hole on the cross member is at the top of th cross member almost above the driveshaft? It seems a little different than what the assembly manual shows but maybe not? Could it have anything to do with the fact that the drum brakes are all brand new and I have not adjusted them yet? And I did have the e brake pedal all the way up but it was very loose and didn't feel connected to anything. Thanks!
Chris
Old August 8th, 2018, 06:47 PM
I've always found that it's much easier to connect the cables first, then install the hooks.
joe_padavano is offline
Old August 8th, 2018, 07:01 PM
Chris
Ok. Thanks Joe. And it appears from the assembly manual that the two aft located hooks are "s" hooks where as the one attached to the crossmember looks like a squared off "c". I don't have this squared off c but rather another "s". Could that be my problem? Is the "c" similar in size to the "s"? All mine are about the same size.
Thanks!
Chris
Old August 9th, 2018, 04:26 AM
Thanks!
Chris
Yes, that's exactly your problem. The hook on the crossmember is significantly longer than the two "s" hooks.
Old August 9th, 2018, 04:32 AM
Chris
Ok. Well that was easy! Now the hard part of finding that "c" bracket in my pile...
thanks Joe!
chris
Old August 9th, 2018, 06:09 AM
Okee dokee, I posted thinking you had all the right hardware. As far as the drum brakes? Nope, I did all new drums at the back and had no problem reconnecting my cables. I also bag and tag everything that comes out of my car, and take pictures of it before hand so I know how it was installed originally.
Allan R is offline
Old August 9th, 2018, 08:06 AM
Chris
Thanks Allan! Yeah, I put 99% of my parts in small clear glass jars (not a good idea because they can break , and have) or yogurt containers. The jars and yogurt containers were all labeled,
as well as the boxes they were stored in along with a master computer list and printout of where every part was placed... problem was that the jars where I used grease pencils or China markers all wiped off from handling them. That was a hard lesson to learn. All the ones where I used a sharpie were fine. So anyone getting into a new project like this do as Allan says and use baggies. And sometimes I wind up finding a part after I already bought a new one.
Chris
Old August 9th, 2018, 09:53 AM
Here's an idea of the relative sizes of the hooks
Old August 9th, 2018, 09:56 AM
Chris
Yeah ok. There's my extra inch and a half I need! And where are those mickey mouse shaped fasteners used? Thanks so much!
Chris
Old August 9th, 2018, 10:04 AM
Yeah ok. There's my extra inch and a half I need! And where are those locket mouse shaped fasteners used? Thanks so much!
Chris
"Locket mouse"???
I assume you mean the three wire spring clips. Those retain the e-brake cable sheaths to the brackets on the chassis. Note "View B" in the lower RH corner below.
Old August 9th, 2018, 10:08 AM
Locket mouse = Mickey Mouse spring clip
These are from my car when I did rear brakes in 2012
EDIT: I only had 2 mickey clips because I didn't do anything with the front cable.
Allan R is offline
Old August 9th, 2018, 10:10 AM
Yeah, I figured the "mouse" part. It was the "locket" that threw me.
Old August 9th, 2018, 10:11 AM
Chris
Gosh darn auto correct 😀
Old August 10th, 2018, 04:47 AM
Chris
So I found my large "c" bracket for the middle of the cable to the crossmember. I forgot that I had it powdercoated so it was in a different box. However I can only find one of the Mickey Mouse spring clips. Perhaps the others broke upon taking them off. I have one more place to look through. If I can't find them does anyone have 2-3 extras?
Thanks!
Chris
Old August 10th, 2018, 06:57 AM
Somewhere on my property there is a massive pile of all the missing parts and tools I've lost over the years. I suspect there is also a large quantity of mis-matched socks along with them.
Old August 10th, 2018, 09:16 AM
Chris
Ha Joe. I'm glad to know I'm not the only one who loses parts despite trying to be organized! So approximately how far down the thread is a good starting point for the nut to be for adjustment? And how do I know that I'm tight enough but not too tight?
chris
Old August 10th, 2018, 09:38 AM
frankr442's Avatar
Take up any slack without actually pulling on the rear cables.
Old August 10th, 2018, 10:24 AM
chris
When you have the cable installed, it should be snug but not tight. I had my car up on jack stands when I did all this so my process was to tighten the adjuster just enough so there was no drag on the rear wheel. Then apply park brake and see if the wheel was solidly locked when turning forward on the wheel. If it would turn even a bit, it's too loose and more tightening would be required. Keep in mind the park brake isn't meant to be a stopping brake, just for parking.
The process is nicely detailed in your 72 CSM on pages 5-8 to 5-10
Allan R is offline
Old August 10th, 2018, 01:24 PM
Chris
Thanks guys! And I do this all with the parking brake pedal disengaged?
Chris
Old August 10th, 2018, 01:40 PM
Yes. After you install the cable, you then test whether your equalizer needs to be tweaked. Play the tension by eye and feel, then tighten the lock nut on the equalizer. Apply the park brake pedal fully. If the wheel will drag but turn backwards, but locks in forward, it's properly set. As per the CSM instructions. I forgot to ask you if you have the 72 CSM Chris, but I thought you do?
Allan R is offline
Old August 11th, 2018, 08:23 AM
Chris
Hi Allan! Thank you very much! Yes I do have the CSM. completely neglected to lol at that. I've been focusing so much on the assembly manual. Your instructions are very much appreciated!
Chris
don71
December 20th, 2018 10:30 AM
sheltonoil
Brakes/Hydraulic Systems
May 10th, 2017 08:13 PM
69'442
March 30th, 2013 07:12 PM
GoodOldsGuyDougie
November 22nd, 2010 08:07 AM
rida142
September 12th, 2010 07:37 PM
Quick Reply: Parking brake cable installation 1972 cutlass
