Disks for Vista Cruiser??
I want to put front disk brakes on my 67 Vista Cruiser, do they use the same as the Cutlass? Are the "kits" from Summit Racing any good? I know there are different kits out there. I have power drum brakes, can I use my existing booster?
The only thing to be aware of is that GM used different size bolts that hold the steering arms to the spindles over the years. The kits all come with the largest of these bolts. You may need to open the holes in the steering arms to match.
OK, If I use the mini kit the rotors, calipers and master cylinder I need are for 69 and up "A" body's, correct? What about a proportioning valve? I had to add one to my Chevelle when I converted it.
Thanks Joe.
Thanks Joe.
Oldsragger
Brakes/Hydraulic Systems
32
June 29th, 2015 01:27 PM
brown7373
June 13th, 2014 05:43 PM
1970_442
July 11th, 2010 06:34 AM
