More brake bleeding issues
Old October 8th, 2017, 10:54 AM
richeyb's Avatar
I've replaced master cylinder for my 72 Cutlass. Atempted to bleed right rear first I get not fluid. I have taken bolt out and made sure it's clean but still no fluid flow. I checked right front and I do have flow. Any suggestions??
richeyb is offline
Old October 8th, 2017, 10:58 AM
sixty9olds's Avatar
Did you bench bleed the master cylinder?
sixty9olds is offline
Old October 8th, 2017, 11:01 AM
Proud Viet Nam Veteran
redoldsman's Avatar
If you use the search function there are probably at least 12-15 threads on here that I believe would cover every possible situation.
redoldsman is online now
richeyb's Avatar
Yes. I bench bleed it....
richeyb is offline
Old October 8th, 2017, 11:07 AM
richeyb's Avatar
yes I bench bleed it
richeyb is offline
Old October 8th, 2017, 11:08 AM
richeyb's Avatar
Reloads an Thanks. I'll search
richeyb is offline
Old October 8th, 2017, 01:04 PM
Remove the bleeder screw and poke in the hole in the wheel cylinder with a piece of solid copper wire. If the hole is blocked with rust, replace the wheel cylinder. If not, replace the hose.
joe_padavano is offline
Old March 26th, 2018, 12:12 PM
richeyb's Avatar
Update... new set of wheel cylinders and master cylinder, ran 21/2 cans of fluid through until clear. Bleed, until got all air out, stopped showing.... went for a ride with booster brakes seemed to worked ok, but had hardly any brake pressure? Push peddle to floor and stopped. Not sure what that means??
Also it appears front fluid is going into back bowl. Assume it is shoot over top? But after short ride front bowl down and back bowl over flowing when I opened top.
Any thought on my 2 issues. Pedal pressure and fluid levels?.
richeyb is offline
PhilGGG
December 18th, 2013 07:06 PM
69350rocket
Brakes/Hydraulic Systems
19
July 29th, 2011 12:41 PM
Deputy442
September 5th, 2008 05:15 PM
Bluevista
May 21st, 2008 10:20 AM
projectheaven
May 15th, 2008 01:11 PM
Quick Reply: More brake bleeding issues
