Super 88 Power brake booster issue
Old September 21st, 2017, 02:29 PM
Chicknj's Avatar
On our 60 super 88 brakes were not the best when I got it and now there worse. I've adjusted all 4 drums, and bled all 4 stopping has improved but pedal is very hard. I unhooked the pcv and the vacuum tank and ran a single vacuum from rear of carburetor to the booster no improvement. I'm assuming my booster is bad. Does anyone know of a booster from what would fit and work properly. I'm also thinking about adding a dual master cyl. And separating the fr. & rear lines to it.
Chicknj is offline
Old September 22nd, 2017, 12:19 PM
D. Yaros's Avatar
I am sure you can get the booster rebuilt. I had mine (1962) done for a reasonable price by these guys -
http://brakematerialsandparts.webs.c...rebuilding.htm
I do recommend them, based on my experience.
D. Yaros is offline
Old September 22nd, 2017, 02:14 PM
Get a correct replacement booster or have yours rebuilt. As for a dual circuit M/C, the cylinder from a 1962-66 Caddy will bolt to your current M/C and provides the dual circuit redundancy.
joe_padavano is offline
slw0501
Brakes/Hydraulic Systems
April 20th, 2017 03:38 AM
jetstar88mike
August 3rd, 2015 09:27 AM
defiant1
March 22nd, 2015 07:05 PM
W-27
December 10th, 2013 10:25 AM
DAYBLISSER
March 13th, 2009 11:05 PM
Quick Reply: Super 88 Power brake booster issue
