Brakes block when breaking
Hi guys,
following issue: When I start my 66´F85 and going to drive the first 3-5 times
I use the breakes, even very smooth the will block (full breaking). After that they will work fine. Any idea what that could be?
66´f85, 330cui, all drum breakes, new break booster
Thank you, Daniel
Thank you, Daniel
If they are locking up temporarily and the issue clears up shortly after driving, it could possibly be corrosion on the drums if the vehicle has been sitting for a long period of time... Other issues could be the return springs, or even a wheel cylinder not retracting as it should...
Yes i mean they lock up. The vehicle did not sit for a long period of time. Could it be to much vacuum during the fast idle? Otherwise I will check or buy new wheel cylinder.
thx
thx
I've had the same symptom with leaky axle seals on the rear too. I suppose bad bearing seals on the front could also cause this. Lube on the brake shoes is NOT helpful for smooth stops.
