Disc brake conversion
I'm doing a disc brake conversion on my car & initially i bought the kit for just the front and later decided to do the rear as well which was a different kit. Here is my dilemma, everything is put together correctly in regards to parts but I'm still getting no pressure. I've bled the brakes several times but still no pressure.
I've called the manufacturer and one associate says the original proportioning valve nerds to come off but another associate says it doesn't matter. They then said I needed different brake lines that they make but I'm really skeptical if this is the answer to the problem. Has anyone had this issue with a conversion? I haven't driven my car in over a year and this is frustrating.
Kennedy, did you bleed the master cylinder before installing it? Usually when you buy a new master cylinder it comes with instructions on how to bench bleed it before install.
BTW, what kits did you buy and what kind of car do you own? I ASSume it's an Olds Cutlass.
I have a 67 F-85 and I bought both kits from Right Stuff detailing
Here is a good read on troubleshooting your brakes.
https://www.getdiscbrakes.com/knowle...ow_brake_pedal
Mocephus
October 1st, 2021 09:45 AM
68442Convertible
Brakes/Hydraulic Systems
June 8th, 2016 08:15 PM
Maverick
June 26th, 2013 08:21 AM
