Drum brakes - Adjuster lever not contacting star wheel
When I assemble the drum brakes on my 1965 Cutlass the self adjuster lever won't rest on the star wheel. It's close enough to adjust the shoes during operation but it does not "lock" the star wheel during rest.
Any idea what could be wrong? All parts are new or like new and I'm 99% sure everything is assembled correctly. It's the same at all four wheels. The lever sits about 1/16" from the wheel.
Bad repro parts? How important is it for the lever to rest on the wheel?
I've replaced the adjuster spring in the picture (driver side) with a white one. Sadly it did nothing for my problem though. The adjuster lever isn't pushed out, it's too high.
Anyway, since I switched it for the white spring (mirrored) it now looks like this (borrowed picture):
I noticed someone had the same problem in this tutorial, see post 48:
https://classicoldsmobile.com/forums...utorial-2.html
Yes. The blue part in this pic that appears to not be brand new is too long. The one the self adjuster arm hooks to on top. You need to play around with the z bend to make it a bit shorter. It'll likely take a bit of trial and error. If the adjuster doesn't touch the star wheel there will be no automatic adjustment.....and eventually the brakes will end up way out of adjustment! Which isn't good for pedal height
I think your problem is that the red spring, pointed at by the yellow arrow in this photo, is reversed along the long axis. It should be mounted as shown in the lower photo below, which is the brake on my '78 Toronado (photo taken before I disassembled and rebuilt so that I would remember how it went together). I know that's not the same as your car, but I'm guessing drum brake design is similar across model lines.
Note how the hook on the left end of the spring points away from you on your installation and points toward you on my installation.
When I redid the rears on my 72 the part that contacts the star wheel did not touch similar to the ops, I put the old part back on and it contacted it no problem. I think the new part was slightly smaller dimensions and just didn't reach like its supposedto.
Problem solved! I tweaked the actuator link to shorten it up a little and now everything works like it should. The lever rests on the star wheel and ratchets like a dream during operation
Yeah, I agree. Something is wrong with these parts. For the record, I only use (supposedly) good brands like Wagner, Bendix and Raybestos. For what it's worth...
Yes, I changed that spring as well. My setup looks like yours now.
Thanks everyone for your ideas and input. It really helps!
I do, and they are still on my car. They work virtually trouble free and stop great. Of course there is that minor issue when going through deep water in the rain, you need to understand the cars limitations.
I guess it is like anything else, the more you work on them the more you get used to it. In my previous drum brake battles, it always left me feeling dirty and semi-puzzled as to why they even still exist today. HAHA!
Awesome I'm glad to know my tip worked! I normally just make the existing Z bend a bit tighter......but what you did works just as well I think that part somehow gets stretched over time.......as loads of gm vehicles have this style adjuster and shortening that link is always the cure!
One thing I was taught like 50 years ago, when drum brakes were the norm...was to bend the springs like the large white one at the top. You should like crimp them so the short end is parallel to the larger leg that goes to the coil. It takes like 2 mins to do them all with needle nose or needle nose vise grips. It won't fix that problem, but it IS good practice. It's like clinching front brake pads, not a lot of people know about it except for the old guys.
Oh man, does that bring back (bad) memories of driving in torrential rain on the Gulf Coast where the water would get halfway up the wheels in just a few minutes. That had a significant impact on braking ability with 4 wheel drums!
I don't mind working on drum brakes, except for those that have tapered axle drums. It is like anything else on the car, once you understand how to do them, it isn't that difficult. When you run into the problem like the adjuster issue posted above, then they can be a little daunting. I have never run into that problem, but now I will know how to fix it if I do. I learn something new every day of my life, and even if I live to be 100, there will always be something new to learn.
I appreciated this. I have the same problem and I've taken everything apart and put it back together too many times trying to Figure out what's wrong. I'll tweak the same part and see if it fixes my problem
I would be concerned about that. The length of the link is specifically designed to prevent over-adjusting of the self adjusters when using the brakes. You've now changed that. I wouldn't be surprised if your brakes overadjust and tighten up after driving for a while. Frankly, until you put the drums on and initially adjust the brakes, the relationship between the lever and star wheel is meaningless. If the shoes are not in the proper location (and likely won't be until the drums are installed), the lever won't be in the right place either.
Seems reversing the lower spring so it mounts with the spring ends outwards and slightly bending the upper arm to shorten it some did the trick. Good suggestions to remember when I work on drum brakes, or for someone like me, to find on a future reference search on OldsmobileClassic.
I can for a fact say that things will not arrange themselves any better when you get the drums on (and initially adjust the shoes). A couple of years ago when I first discovered this problem I thought (hoped) just that. Taking it apart now things are exactly the same - lever not contacting star wheel, no self adjusting brakes...
The length of the links and adjuster levers are specifically designed so that once the brakes are properly adjusted, an application of the brakes doesn't move the adjuster lever enough to engage the next tooth on the star wheel, thus preventing overadjusting of the brakes. Changing the length of the link can cause either over adjusting or under adjusting. They were the correct length when they left the factory. Why would they need to change? Clearly something else was out of place.
Let's try this again. Every time you apply the brakes, the pivot point where the adjuster lever is attached to the rear shoe moves slightly outboard and up (the shoes move out due to the expansion of the wheel cylinder, and when driving forward, friction moves the shoes slightly counterclockwise on the LH side and clockwise on the RH side). This pulls the lever "up" relative to the star wheel. When you release the brakes, the return springs pull everything back to normal positions, which then moves the adjuster lever "down" relative to the star wheel and thus turns the adjuster.
I agree everything was correct when the car left the factory. However, that was over 50 years ago and the only things original now are the backing plates.
1966 CSM:
I ran into this adjuster/lever contact issue ever since I ended up replacing my adjuster. I found the new adjuster screw caps had a lot of play to the shoes (mine were really bad, both ends, not sure if parts are bad or what). I ended up digging out my original GM adjusters and swapped back to the old GM end caps. They fit the shoe snuggly, no back and forth float like the new parts had. The old GM parts fit like they should, so now the adjuster and lever are lined up.
Found this tread that may provide some helpful info.
https://www.chevelles.com/threads/dr...stion.1089742/
I ran into this adjuster/lever contact issue ever since I replacing my adjuster. I found the new adjuster screw caps had a lot of play to the shoes (mine were really bad, both ends, not sure if parts are bad or what). I ended up digging out my original GM adjusters and swapped back to the old GM end caps. They fit the shoe snuggly, no back and forth float like the new parts had. The old GM parts fit like they should, so now the adjuster and lever are lined up.
