master cylinder issues
Old May 29th, 2017, 08:18 PM
Fox Stuart's Avatar
ok so this is my first post and im completely new to the whole forum thing but have hit a wall with my car. i have a 1960 dynamic 88 and i cant find out what master cylinder fits it , i had napa order one but the stroke is off and now im wondering if i can get it somewhere else or if i can cross refrence the part numbers on the old one. i have found out that a bendix is a single outlet and a maureen is a dual outlet , so i ordered a bendix one and tried to put it on and it dosent seem deep enough and everyone i call said that is the only one available, i just got this car and dont know alot about oldsmobiles so trying to find out as much information as i can
Fox Stuart is offline
Old May 30th, 2017, 05:59 AM
Welcome. Oldsmobile didn't use a dual outlet master cylinder until the 1967 model year. Your car could have come with either the Bendix or Delco Morraine master cylinder. Both are single outlet (whoever told you otherwise is wrong). The difference is in the depth of the hole in the back of the piston where the pushrod presses on the M/C piston. If the stroke is wrong with the Bendix, that's probably telling you that your car uses the Delco Morraine master. Good luck.
joe_padavano is offline
Old May 30th, 2017, 05:06 PM
jaunty75's Avatar
"Morraine" is certainly better than "Maureen," which had me rolling on the floor laughing, but the company is/was called Delco Moraine.
https://www.wikiwand.com/en/Delco_El...Delco_products
jaunty75 is offline
Old May 31st, 2017, 06:19 AM
Wow, I just missed that completely. I read "morraine".
Old May 31st, 2017, 11:08 AM
Rocket Renegade!
I prefer Delco-Lorraine myself.
BangScreech4-4-2 is offline
mbat
Brakes/Hydraulic Systems
April 12th, 2021 07:40 AM
KQQLCAT
November 7th, 2016 04:45 PM
Chumley
October 31st, 2007 09:17 PM
<marksz71>
October 20th, 2006 07:14 PM
martine
February 5th, 2004 10:28 AM
Quick Reply: master cylinder issues
