Line and fitting sizes
Old April 29th, 2017, 07:07 AM
CutLS442's Avatar
Hi all.
Im doing a LS brake upgrade on my 72 Cutlass.
I thought i had everything covered but when i was starting on the lines i discovered that the main brakeline from the distribution block to the Axel hose is a bigger line.. lol.. well i should have looked before, but...
Since the lines are in good shape and im using a adjustable wilwood proportioning valve I want to use an adapter from the normal 3/16 line to the 1/4 (?) line and roule out the frame mounted distribution block near the manifold.
The question is what type of adapter will i need?? I have no idea of the fitting size on the bigger line.
Thanks!
CutLS442 is offline
Old April 29th, 2017, 10:23 AM
Originally Posted by CutLS442
Hi all.
Thanks!
Yes, the front-to-rear line is 1/4". Google inverted flare adapter fitting for the right part. Specifically, you want "IFF to IFM" adapters (inverted flare-female to inverted flare-male).
http://www.speedwaymotors.com/IFM-to...ters,6458.html
joe_padavano is offline
Old April 30th, 2017, 02:52 PM
CutLS442's Avatar
Thanks Joe!
CutLS442 is offline
yamahondarider
June 23rd, 2015 07:34 PM
tgilligan
March 12th, 2014 03:51 PM
71supreme
March 6th, 2011 12:24 PM
Creativeindy
August 10th, 2009 01:57 PM
Flye
July 31st, 2009 04:03 PM
Quick Reply: Line and fitting sizes
