Front drum brakes
Front drum brakes
I have a 62 dynamic, the front drums are seized. I have tried everything I know short of drilling out the holding pins and removing the wheel cylinder bolts. Any ideas that will help?
Why haven't you disconnected the brake line, unscrewed the cylinder screws, and cut the heads off of the retaining pins (all you usually need to do is to grab the heads with a pair of nippers and use a hacksaw blade or a whizzer, or just give a good squeeze on the nippers)?
If the shoes are stuck to the drums, or just can't be retracted out of the wear groove, it's pretty much the only way, and it's easy.
delta254
Brakes/Hydraulic Systems
January 27th, 2013 08:11 AM
1carsick
23
October 2nd, 2012 05:50 PM
