single piston master to dual
A buddy has changed his 61 to a dual line master cylinder. Put on a new booster and a new master cylinder. He has about 1/8 push in from the brake pedal pushrod into the booster. The output rod into the master cylinder has about 1/8 clearance in the master before it pushes the piston. The master is for a drum/drum system with no distribution valve. His brakes take a lot of pressure to stop the car. Question is, does he need to change to a smaller bore master? Or what?
First, fix the pushrod problem. Are you sure there's clearance? Typically the dual circuit M/Cs require a SHORTER pushrod than the single circuit M/Cs. This is critical, as an improper pushrod length can prevent the M/C pistons from uncovering the compensating port. If the pushrod really is too short, this is also a problem.
Second, the distribution block serves only to provide a place for the differential pressure valve that illuminates the BRAKE light on the dash as your foot goes to the floor. You don't need it and it's presence or absence has no affect on pedal pressure. It is NOT a proportioning valve.
Third, while you didn't explicitly say so, I ASSUME we're talking about a four wheel drum vehicle. If so, I ASSUME the new M/C is a drum/drum M/C with residual pressure valves in the outlet ports.
Finally, the new M/C bore should be the same as the old one. If it is, and the system is bled properly, and the pushrod is adjusted properly, there should be no difference in feel or performance.
Since you didn't tell us the bore of the old and new M/Cs, it's a little difficult to provide useful info.
arcee1951
Brakes/Hydraulic Systems
March 1st, 2016 06:05 AM
69Rocket350
February 28th, 2012 07:31 PM
CutlassLegend
August 7th, 2011 05:15 PM
martine
February 5th, 2004 10:28 AM
