wheel cylinders for 59 Olds
Likely one is low grade Chinese garbage, while the other...
... may be low grade Chinese garbage.
For the price, I'd get the cheap ones and see how they work. If they start leaking too soon, you can try the expensive ones, but you may discover that they are the same thing.
By the way, I haven't checked the part numbers, but these are probably also available from you corner parts store.
Don't know what model you have. Rock auto lists Dorman and centric.
Whatever you buy, I would open up and inspect inside before installing. If assembled wrong or defective it is easier to deal with it before installing.
Been there.
Been there.
I'm appreciative of what Fusick has done for Oldsmobile owners, but as an example, Thorntons sells the 1965-70 B-body dual exhaust manifold for $229. Fusick sells the same manifold for $269. It's the same part made at the same Chinese foundry.
So am I, and I've said many times that they're the gold standard in the Oldsmobile hobby and that you'll never go wrong buying from them. BUT, they capitalize on this reputation, and they're among the most expensive suppliers out there with obnoxious minimum order policies and shipping costs. It pays to shop around because there are only so many manufacturers of the parts that all of the various vendors sell, and you'll often find the exact same part at very different prices.
A lot depends on wheather you are looking for front or rear wheel cylinders.
Rear wheel cylinders are available from many sources and are usually $10 or less.
Front wheel cylinders for 59's are a lot harder to find , and are typically $40 and up .
As others have said , most are made in China , so it's a crapshoot if you get a good one .
yeahbuddy
Brakes/Hydraulic Systems
April 5th, 2015 01:52 PM
Lady72nRob71
March 14th, 2014 01:10 AM
1k442
November 30th, 2009 12:37 PM
