Sticking Brakes..lights
Old May 15th, 2019, 01:22 PM
"I need a couch"
pops1958's Avatar
So I just got my refurbed booster back from Power Brake Exchange in San Jose CA. Very pleased.
i picked up my car (69 442) from my mechanic who installed the booster. I drove it home to discover the brake lights remain on after turning off the car. I have pulled on the pedal to no avail. Before I drive back across town in this Mississippi heat w/o a/c is there something that even this most dangerous mechanic should look at? Thanks.
pops1958 is offline
Old May 15th, 2019, 01:24 PM
D. Yaros's Avatar
There should be an adjustable brake light switch under the brake pedal arm. It may need adjusting?
D. Yaros is offline
Old May 15th, 2019, 01:34 PM
Curious why you titled this post "Sticking brakes...lights"
Are the brakes sticking or not?
Vintage Chief is offline
Old May 15th, 2019, 02:15 PM
The brake light switch closes when the pedal is pushed and the pedal arm moves away from the switch. Look under the dash and make sure the switch is connected to its bracket and the wires are connected to the switch. If the switch is just hanging loose, the lights will stay on, or as said above, the switch may need adjusting to bring it closer to the pedal arm.
Fun71 is offline
Old May 15th, 2019, 03:44 PM
Or the pedal rod clevis was not adjusted correctly and the pedal is not coming back far enough.
oldcutlass is offline
Old May 15th, 2019, 07:16 PM
"I need a couch"
pops1958's Avatar
Thank you again for the counsel. I'll let you know.
To Vintage Chief, I guess I thought the brakes were sticking causing the brake lights to remain on. Sorry if I misled.
I took a picture of the switch but cannot get it to post.
pops1958 is offline
Old May 15th, 2019, 08:01 PM
No worries. If the brake were sticking, it might present a different method of diagnosing the issue. Good luck.
rsmith850
July 20th, 2018 05:52 AM
57droptop
May 31st, 2017 11:33 AM
mauls
Brakes/Hydraulic Systems
May 11th, 2015 05:44 PM
Del70
August 2nd, 2011 04:40 PM
projectheaven
July 20th, 2008 07:03 AM
Quick Reply: Sticking Brakes..lights
