questions about front drum brakes - cutlass/chevelle
I picked up a set of Chevelle drums, hubs and spindles from a 70 Chevelle for my car (71) and when I took the outer bearings out they were numbered LM11949 and when I search for that I find matches for Chevelles, but not Cutlass. I assume they are equivalent. Also, there was a disk on the spindle behind the hub that is made out of some fiber material, like cardboard. I don't see that on any cutlass or Chevelle brake how tos. What is it and where do I get them? I haven't taken the rear bearings out so I have no numbers on them yet. Who sells US made bearings?
Thanks again for the help.
I thought they were the same. The setup I bought was complete and assembled spindles to drums. The guy said he had repllaced or repacked the bearings and everything was read to go. After I pulled the hubs off This was up against the spindle, same thing on both. Sorry about the size.
Ah, this is the seal that goes between the backing plate and the spindle. Frankly, I've never reused them, and I don't think you can get new ones. I've never really seen the need for it, and I think GM finally stopped using it on later cars. Don't worry about it.
Fiber disk
Joe is right about placement, but not availability. I bought replacement disks to match these from Inline Tube - PN INL10443. $8.00 gets you two.
I have a separate question regarding Hub part numbers and placement that I have not been able to find answers for in either my hardcopy nor WildAboutCars' online parts manuals. I will start a new thread.
delta254
Brakes/Hydraulic Systems
January 27th, 2013 08:11 AM
1carsick
23
October 2nd, 2012 05:50 PM
