Installing Brake Calipers on 1968 Looking for Help
Looking for any advice tips on installing brake calipers in a 1968. These are the four piston ones. I have struggled both times I have had to deal with them and I would assume their has to be an easier way of accomplishing this. The trouble I gave is getting the pads spread out far enough to get the calipers back on without loosening any lines and then having to bleed again.
Is is there any tips/ tricks that I need to know? Any known tool that can aid in this procedure. I have not found anything that helps.
Thanks Tim
Thanks Tim
I did find a tool this last time to push in the pistons but by the time I got the pads back in and tried to get it back on the rotor the pistons had made their way back out and would not stay pushed in.
I recall using a socket between the pads to hold them apart and then sliding the caliper on. And while we are here, if single piston calipers do not use a spring in the piston, then why is one necessary on a four piston caliper?
Make sure...
Make sure you get one of my ++ N.O.S.++ Asbestos ++ sets of brake pads before you assemble , you will hate life otherwise!!!!!!!!
Always best to simply call me -- Craig -- 516 - 485 - 1935....
BackInTheGame
Brakes/Hydraulic Systems
December 29th, 2018 07:48 AM
76olds
August 6th, 2015 03:03 PM
