Drum brake help
Drum brake help
Any tips from you guys how to get the drum off, I have oversized control arm BMR tubular and the adjustment slot is pretty much covered up, While driving tonight I heard a twang and a grinding noise from front driver, limped the car home and now have a problem of trying to get the drum off, I got in there with a light and something blew a hole through the plate, maybe the spring?
Here the pic of the hole in the plate
Pic of the arm in the way
Drum brake help
Any tips from you guys how to get the drum off, I have oversized control arm BMR tubular and the adjustment slot is pretty much covered up, While driving tonight I heard a twang and a grinding noise from front driver, limped the car home and now have a problem of trying to get the drum off, I cant figure out how to release the brake if I cant get into that slot. I got in there with a light and something blew a hole through the plate, maybe the spring?
I've had some backing plates without the hole to put the brake spoon in. Prybar or big cheap screwdrivers, one on each side to work the drum loose and slide off the shoes. That's what I've done.
John
John
If something went through the backing plate they must be getting mighty thin. You may want to think about replacing. Is your drum part of the hub? You can try forcing drum side to side and see if you can work it past the shoes, if not, last resort use large adjustable wrench peel back plate to get at star adjuster. ONLY AS A LAST RESORT. Guy
I hadn't paid attention to the hole in the backing plate. Yes, if its thin it might be good to replace it while your there. Since lots of people have swapped drums for disc I suspect several members here would have a replacement for you at a reasonable price. John
No guarantee but you could try grinding off the back of the hold down pins, and remove the outer wheel bearing. This may allow enough room to pull the drum either off with the shoes or allow room to get to the adjuster wheel. Be careful springs may start to fly when trying to remove the drum this way, wear eye protection.
Good luck!!!
Good luck!!!
Ok I have it off and looking to buy a rebuild kit, it seems all the backing plates for the front being sold are for disc brakes and not drum, is that what goes on the front even though its drum?
John
"Ok I have it off and looking to buy a rebuild kit, it seems all the backing plates for the front being sold are for disc brakes and not drum, is that what goes on the front even though its drum?"
On drums I've always heard it referred to as a "backing plate", on discs a "heat/dust shield" and "caliper mounting bracket/spindle".
None of these are interchangeable between drum and disc.
Good luck!!!
Good luck!!!
Common sense should tell you that they aren't the same part.
I just looked through one of my wish list books Year One list backing plates for drums. My False teeth fell out at the price. Others here have the right idea list what you need in the parts wanted section and get good quality USA made parts. Guy
These are the same front brakes used on 67-69 Camaros and 68-74 Novas, so I'm amazed that no one reproduces them. The Camaro houses are asking stupid money for used ones ($80 each used?!?!?!). Wow.
Got to thinking which puts me in trouble right from the get go! While you are fixing the obvious, you should look at doing maintenance to your whole brake system. Inspect the rears also, when was the last time you changed the brake fluid. People think about their brakes about as much as they think about the coolant in the engine. Only time they do is when something goes wrong. Since you are already working on the brakes check out everything, it will pay dividends down the road. Not to mention peace of mind.
Hello,
Sorry to read about your troubles. As it happens, I just converted my '69 Cutlass S over from front drums to discs. I was one step away from throwing all of the drum hardware in the scrap heap about a month ago and thought 'somebody might want this' so I kept it and have cleaned it all up. It's all original GM stuff and in great condition (car had 80k miles and was well maintained).
I have no idea if it has any value unless somebody is doing a nut and bolt resto or somebody like you who just wants to replace old parts. I'm not trying to make a sale here, I just saw your thread and thought I might be able to help you out. The parts are for a '69 and I'm not sure what year you have (picture looks like a '71 or '72). I don't know if everything would fit but I'm sure one of the other guys would know. I suspect it's all the same.
I have everything - backing plates, drums (original bell shape and all lugs good), small hardware that bolts to the back of the backing plates and some of the brake hardware (adjusters). The only thing I threw away were the shoes and springs.
Let me know if you're interested. I was going to list it all in the parts for sale section in a week or two.
Here are some pics of what it looked like after I took the drum off
Are things installed right what is there lol, the writing be up side down at the top, I see a L on the right side etc
The parts that fell out when I took the drum off, I think a pin piece is missing
and the swiss cheese backing plate thats on there now, I just rebuilt the whole front end except the brakes cause Im gonna do a disc swap this winter, but i will need to do a fix to get me through the summer and fall..
So I emailed the guy that pulled it from the 69 chevelle and there are some differences, Pretty sure he pulled the passenger side, I wont no until he pulls the driver because the orientation of cylinder is wrong, I need that flat part at 10 not 2, and the other 2 small holes are clocked wrong. Another thing to note is the hole at the top where the castle bolt goes through is smaller on the donar so if its like that on the driver he pulls there gonna be an issue, the plates also have other small differences, I wonder if my 4 door is not the same.
The other side will have the same orientation as yours. They are mirror images. There are minor detail differences in the shape of the flange around the outside, but that has no impact on functionality. One of you apparently has the backing plates swapped.
It appears to be correct. When I do my Brakes I do one side at a time so if i'm not sure about something I got the other side as a reference. You might want to adjust the shoes out to the drums as close as possible, so you won't have to spend all day backing up and hitting the brakes to adjust them,since you will not be able to adjust the star wheel through the slot.
the green spring kinda dosen't feel like its right, has a lean to it, I wasn't sure if it sat in one of those metal pockets they give in the spring bag, probably should check the other side since there were springs that fell out when the drum was pulled and I lost a few pieces.
By my what looks to be a Bendix system, I got lucky, because the shoes have been recently replaced. Despite that, I'm still going to perforate the backing plates, so that I could pry the adjusting mechanism apart. When I'm done, I'll simply install a proper-sized rubber plug. By your plates, you can simply cut the hole and use the old plugs from the originals. Putting the old plate over the next one, simply trace the hole with a scribe and then cut and file accordingly.
The adjustment's regulated by the fine teeth located between both parts where that Label's shown:
Besides the hold-down spring issue Joe mentioned, it also looks like someone has installed two secondary brake shoes.
The primary shoe has friction material that is shorter and that shoe is installed toward the front of the vehicle.
The secondary shoe has friction material that is longer, and it should be installed toward the rear of the vehicle.
I suspect if you take the drum off the other side, you'll find two primary shoes installed on that side.
#32
Good call everybody on all points, just one other point SkyHigh has oversize control Arms that covered up the access slot tracing out and cutting a slot in his new backing plate will not solve his problem adjusting the shoes manually. He will have to lower it down in the Plate. SkyHigh you are looking at doing a Disc Brake conversion this fall. Don't bugger up your "new Plates" just pre adjust the shoes so you can barely be able to slide the Drums on and you will be fine. Then you will be able to help someone else in the future. Good Luck
#34
#37
#39
Ok this should be better thanks to your keen eyes, thanks alot guys, I really appreciate that, changed the shoe to the right 1, fixed the green spring, packed the bearing, bleed the brake and took it for spin and yes the adjuster is on, I just didnt get that pic lol.
joe_padavano
September 14th, 2022 09:44 AM
