70 442 Hard brakes
70 442 Hard brakes
Tried looking through previous threads and I think I have found the answer, but will ask again for clarification: When braking the pedal feel is hard. Enough to push me back in the seat during a panic stop. I am noticing rough idle and hear a ticking noise much like a vacuum leak. Futher investigation reveals some air (or vacuum) coming from the connection between the power booster and the M/C. Talking around with the guys and everybody has a different answer. One guy says replace M/C, another says build a gasket for the leak. Another says the power booster is shot. This is my daily driver and not too concerned about originality but the car shows well at gatherings. First: what's the problem and second: what's the cost difference between the original look and less expensive fuctional parts?
Lots to ask, but you folks have been very helpful in the past.
Mitch
Mitch
Since a bad brake booster causes a hard pedal, I would say that is bad. I am guessing the rubber inside the booster is cracked and leaking. I think a way to check if it is leaking is by hooking up a vacuum pump and see if the booster holds vacuum.
Mitch
Mitch
1carsick
Brakes/Hydraulic Systems
23
October 2nd, 2012 05:50 PM
cjprm
May 19th, 2011 09:17 AM
russell-t
April 30th, 2011 05:56 AM
