1969 442 rear emergency brakes
I bought a 1969 oldsmobile 442 and it does not have emergency brakes and its a 4 speed
We'd need a little more info to help you diagnose the problem:
1) Is there a E-brake pedal assembly on the far left side of the driver's foot well? If not, you'll need to find a pedal assembly and get it installed.
2) Is there an E-brake cable running from the pedal assembly to under the car, where it attaches to and pulls on the secondary cable which splits to the left and right rear E-brake cables that go from in front of the rear LCAs to the rear brake drum backing plates? If any of those 4 cables are missing, you'll need to purchase them and get them installed. There are also 2 metal "links" that connect between the ends of the secondary cable and the two rear cables, if those are missing then you'll need new ones installed.
3) Are the rear E-brake cables properly attached to the E-brake mechanism in the rear drum brakes? If not, you'll need to get that fixed.
Let us know what you have or don't have and we can go from there.
Since the mind reading thing STILL isn't working, how about you give us ALL the info about this car so we can give you a useful answer? Are you saying it has a rear disc brake conversion? Making us guess that and any other pertinent info isn't going to get you useful info. Since a disc brake conversion would be an aftermarket or custom installation, without photos of the calipers it's impossible to tell you anything.
Wilwood makes about a hundred different disc brake calipers. How about telling us WHICH ONES you have, or better, posting a photo.
Now how about a photo of the BACK of the caliper that shows where the E-brake connection would be? FYI, if these calipers don't have an E-brake provision, you're kind of screwed.
Wilwood calipers designed for an E-brake have the actuating mechanism on the back, like this:
I'm not familiar w/ the Wilwood rear disc brake packages for A-bodies, but I would think that they offer parts to properly connect their e-brake mechanism to the existing cables (or replacement rear cable assemblies).
Race cars don't require E-brakes. I guarantee you that every product Wilwood sells has a legal disclaimer someplace. By the way, Wilwood does sell disc brake kits that use a separate drum brake E-brake inside the rotor hat, just like Corvettes. The OP's car doesn't have that either.
Allow me to re-phrase that. Seems offering a rear brake conversion for a street-driven car without a E-brake provision would be a product liability disaster waiting to happen.
My '07 300C's rear disc brakes have a mini drum E-brake that scrubs the inside of the rotor. Being the only rear disc brakes I've ever worked on, I assumed most cars w/ rear disc brakes had that setup.
[QUOTE=JohnnyBs68S]Allow me to re-phrase that. Seems offering a rear brake conversion for a street-driven car without a E-brake provision would be a product liability disaster waiting to happen. [/QUOTE]
My point is that Wilwood sells a lot of race car parts. The fact that whoever put those calipers on the car didn't select the correct ones for street use is not Wilwood's fault.
hey joe thanks for the patience in speaking with my son.....he is a little disabled and was trying to help......those willowwood calipers were made for drag racing and did not have any e brake mechanism.....they were removed and replaced with a master disc brake conversion and an after market cable set up that works great now.....thanks again Vinnie
Not that it matters anymore do to the most recent post, but wilwood also makes supplemental external parking brake calipers to add to their systems that do not have the internal drum style e-brake. Some newer "super cars", "hyper cars", and "exotics" use systems like this as well.
Also, to Joe's point, every part that wilwood sells comes with a warning card like this inside the box. As well as multiple other warnings. I mean every part. If you buy a kit, there is a warning card in each rotor box, in each rotor hat box, in each caliper box, in the pad box, in each backing plate box... you get the point. These cards are in addition to the warnings printed in the instruction manual and the warnings printed on the outside of EVERY individual box. As the card says DO NOT ASSUME ANYTHING. Many of the warnings also say the parts are for race use only just as an additional way to legally cover their behind
