Trunk Brace?
Old June 28th, 2015, 09:32 AM
Chuxter's Avatar
Trunk Brace?
Hopefully the attachment is here but Im looking for a new Brace that goes across the bottom of the trunk that the last set of body mounts sits on. Is this part available or are we looking at a donor car situation or has anyone ever fabricated one?
Chuxter is offline
Old June 28th, 2015, 10:21 AM
oldspackrat's Avatar
I or probably a few others on this site will have that part. I'm going on vacation tomorrow & will be gone for about a week or I'd get pix for you. I'm sure someone else will post soon but if not, contact me next week?
oldspackrat is offline
Old June 28th, 2015, 11:11 AM
AzChevs's Avatar
I have one off and ready to go that was taken off the spot welds, no rust and mounting nuts are nice. The only problem is a small section in the middle top edge was cut with the tail panel by the previous owner.
AzChevs is offline
Old June 29th, 2015, 07:06 AM
Chuxter's Avatar
What do you want for this piece and any idea shipping price to 64505?
Chuxter is offline
Old June 29th, 2015, 12:12 PM
68442's Avatar
Yes, This part is available brand new aftermarkert
68442 is offline
Old June 29th, 2015, 12:57 PM
Chuxter's Avatar
Through who? Part#
Chuxter is offline
Old June 29th, 2015, 01:33 PM
68442's Avatar
I don't have a part number But They have them listed on ebay. BTW the GTO uses the same. if this helps your search. ebay Number#390286487274 The only reason this is not listed for a cutlass is it has 2 1/2"punched holes not used for a cutlass. I have used these on cutlass's personally on a 68 and a 70 442
68442 is offline
Old June 29th, 2015, 01:52 PM
68442's Avatar
http://www.championclassicauto.com/q...3351_3410.html
Here is one for a 69 chevelle that is also the same
68442 is offline
Old June 29th, 2015, 01:53 PM
Chuxter's Avatar
So This fits it just has an extra set of holes? I looked it up and even called Tamraz and they had no Idea
Chuxter is offline
Old June 29th, 2015, 01:57 PM
68442's Avatar
http://www.ebay.com/itm/1968-GTO-Old...-/181083462022
Here is another one on ebay
Compare it to yours
This one i see doesn't even have the holes i mentioned. so this is is even better
I just did a 70 and found the part to be identical other than two small holes. I can take a photo of it on my car as the car is still apart if you want.
68442 is offline
Old June 29th, 2015, 02:07 PM
68442's Avatar
My point with the holes is you see on your picture the holes to the left and right of where the filler neck would be? On the cutlass these are not used so they are just holes. But on the GTO they are used and have a threaded nut behind the hole.
68442 is offline
Old June 29th, 2015, 03:13 PM
70vert's Avatar
I used one in my 70 convertible and it was identical. The only difference was the new one didn't have the little hole for the filler neck support.
70vert is offline
Old December 6th, 2017, 02:44 AM
armycav0's Avatar
so glad I found this post as it is going to save me the headache of fabricating a part of this!!!!!
armycav0 is offline
musicars
Body work
August 15th, 2013 09:32 PM
Ranzan
January 30th, 2010 01:52 PM
redvettemike
May 31st, 2009 04:47 PM
Cutlass69S
October 22nd, 2008 07:57 AM
lil_no
February 11th, 2008 12:41 PM
Quick Reply: Trunk Brace?
