A Pillar Drip Rail
Old April 7th, 2019, 01:04 PM
ajr2820's Avatar
A Pillar Drip Rail
How do you remove this from a 72 Supreme? I removed the 3 screws, but it won’t budge. Don’t want to ruin it. Anyone have any tips?
ajr2820 is offline
Old April 7th, 2019, 07:16 PM
70Post's Avatar
Post a pic.
Are you really referring to the stainless A-pillar weatherstrip channel??
Hardtop or convert?
70Post is offline
Old April 8th, 2019, 03:51 AM
ajr2820's Avatar
I'm referring to the piece that the stainless clips over. I have some A pillar rust to repair. I have to weld in the patch and if I could remove this would make the job easier. It appears to be held on by 3 screws, but won't budge after removing the screws. Will send a pic when I can get one if needed.
ajr2820 is offline
Old April 8th, 2019, 11:07 AM
70Post's Avatar
No need for pics yet - I've pulled one of those and it didn't take any cutting, etc from what I remember. There may be chaulk underneath it (b/n the "topside" of that piece and the actual A-pillar metal) that is keeping it well stuck in place.
After talking with another buddy of mine today that has also pulled these....he agrees....the factory chaulk is pretty good stuff and will hold it on fairly stubbornly even after removing the screws. The factory typically chaulked or sealed up a lot of pieces like this to prevent water leaks which would have been a customer service nightmare if they hadn't.
You might try getting under an edge with a very sharp/stiff putty knife and tap on the knife to see if you can start separating it.
70Post is offline
Old April 8th, 2019, 11:10 AM
ajr2820's Avatar
Thanks. That's what I thought it might be. I just wanted to be sure before getting too rough with it.
ajr2820 is offline
Old April 9th, 2019, 04:05 AM
ajr2820's Avatar
This thing still won't budge. Will putting a little heat to it to soften the putty work?
ajr2820 is offline
Old April 9th, 2019, 11:30 AM
70Post's Avatar
It can't hurt to try.
Did you remove the chalking out of the drip rail channel on the top/outside? It's also fairly mean stuff and could be adding to the resistance.
70Post is offline
chrisneu68olds
November 17th, 2014 06:16 AM
auto_editor
October 18th, 2013 11:36 AM
Hawk1061
Body work
April 9th, 2013 08:27 PM
455man
May 24th, 2011 07:13 AM
71 Cutlass
Body work
January 1st, 2011 05:39 AM
Quick Reply: A Pillar Drip Rail
