68 Cutlass 442 mouldings and chrome - ClassicOldsmobile.com
Go Back  ClassicOldsmobile.com > Repair & Restoration > Body & Paint > Body work
68 Cutlass 442 mouldings and chrome >
Old February 1st, 2019, 06:04 PM
Hey guys, along the back of my 442 on the trunk is the mouldings that says ďOldsmobileĒ
on the quarter panel are little chrome pieces called quarter panel extension cap moldings.
Mine are pitted. Iíve tried to buy reproductions of these and they are come in a brushed metal color which doesnít match my trunk molding. Anyone know why they donít match? Did most cars come with brushed moldings? óBilly
Billyaxe is offline
Old February 1st, 2019, 06:16 PM
allyolds68's Avatar
The inlay is a light silver. If yours are all chrome the original silver has been removed
allyolds68 is offline
Old February 2nd, 2019, 08:58 AM
Thanks. Do people completely take the paint off? Because I donít see any that have paint half on? Iíve searched a lot of photos and that Olds trim across the trunk is very often seen as all chrome. If I wanted to paint it what color should I use? Anyone know? Thanks óBilly
Billyaxe is offline
Old February 2nd, 2019, 10:33 AM
allyolds68's Avatar
I painted the whole thing a light silver and then block wet sanded or used paint reducer to rub off the color from the top surface. It wasnít the same color Silver I used for the headlight buckets but I donít remember exactly what color it was. I remember buying three or four spray cans and spraying test pieces until I matched a pitted one I had that hadnít had the paint removed.
Old February 2nd, 2019, 10:41 AM
Randy C.
rcorrigan5's Avatar
I cleaned mine up real good, removing all the old paint. I taped off the edges, painted the center part, and then used a rag with a minute amount of laquer thinner on it to clean off the tops of the letters. Randy C.
rcorrigan5 is online now
Old February 2nd, 2019, 10:42 AM
Randy C.
rcorrigan5's Avatar
Here's a pic. Randy C.
Last edited by rcorrigan5; February 2nd, 2019 at 10:43 AM. Reason: posted the same pic twice - didn't mean to do that.
Old February 2nd, 2019, 12:52 PM
Wow! That really looks great. Iím gonna do that. Anyone have an idea of what color silver that might be? Matt finish I guess. Here is what mine currently looks like. óBilly
Billyaxe is offline
Old February 2nd, 2019, 03:15 PM
Randy C.
rcorrigan5's Avatar
It's been awhile - I did mine back in 2007. I believe the color I used was "argent" but let others chime in to verify. Randy C.
Old February 2nd, 2019, 07:00 PM
1968 Olds Cutlass S
jdana24's Avatar
Randy helped me when I restored my trunk molding. I used Krylon Dull Aluminum. Like Randy said, use a rag or a Q-tip with just a small amount of lacquer thinner and slowly rub with a light touch.
jdana24 is offline
Old February 2nd, 2019, 08:08 PM
Randy C.
rcorrigan5's Avatar
Dull aluminum sounds right. I was looking through my old spray cans and found a can of Seymour lacquer dull aluminum and I'm pretty sure that is what I used. It's the same paint I used for all the silver-colored plastic pieces at the front of the car for both my '68 & "69.
Randy C.
Old February 3rd, 2019, 06:07 AM
allyolds68's Avatar
Randy C.
I think if you find an original trunk molding youíll see that the Krylon Dull Aluminum is too dark.
The molding I was matching had been taken off a convertible Cutlass S in 1978 and stored inside. It was definitely a lighter silver. I would have used it except it had too many studs broken off and I never could come up with a successful way to re-attach those studs.
Old February 3rd, 2019, 08:10 AM
Thanks for al the tips and suggestions. I have the quarter panel extension molding pieces which has the color on it. Iím gonna do some silver and dull aluminum paint tests to see if I can match it.
Ill post a pic when Iím done. óBilly
Billyaxe is offline
Old February 4th, 2019, 11:29 AM
droldsmorland's Avatar
I used "south of the border" chrome in a spray bomb and then wipe the high spots with a soft Kimberly Clark paper towel & thinner.
Had to wipe it clean 3x and respray it to get it right.(perfectionist)
Once it weathers a bit it looks like a lighter shade of argent silver. Its as close to OEM as I could get. Once weathered/aged a bit its perfect. By weathered, I mean occasional washing and sunlight while on car show duty...not abandoned in your yard for 10 years...
After it completely cures, a month or so, I waxed the whole thing with carnauba. Wipe off wax with a very soft towel (K-C towels are great for this) Clean the crevices with a very soft toothbrush. This enhanced the aging look too.
Come to think of it. I have used this method on the grill/headlight buckets and the SS2 bolt on centers. Same OEM looking results. I did all this in 1990. Still looks great.
Ill post a pic of the above once on home computer.
droldsmorland is offline
Old February 10th, 2019, 09:51 AM
So I think I found the answer as to why my trunk ďOldsmobileĒ molding is completely chrome and shows no signs of silver paint even in the cracks or edges - which I have been told came with silver paint on it.
Ive looked at replacing the quarter panel extension molding (pictured) and have come across silver painted ones only. There is another version of the quarter panel extension molding that is longer and does not have paint on it. The longer one is meant for the convertibles. So I think the olds trunk molding on convertibles came in chrome and not painted. Can anyone else confirm that?
so I think someone changed the Olds molding on my car and used one from a convertible. óBilly
Billyaxe is offline
Old February 10th, 2019, 10:23 AM
For 68 & 69 the Coupe used a longer trunk molding and shorter fender extensions. The opposite is true of verts. They do not interchange. All had the silver inlaid paint.
Old February 10th, 2019, 11:30 AM
Randy C.
rcorrigan5's Avatar
Yes, what droldsmorland said! I had the originals on my '68 convertible which I stripped and repainted so I know the silver was there originally. There was no difference in the paint trim on these pieces between hardtops and convertibles. The only difference was the lengths of these pieces, depending upon if the car was a hardtop or a convertible.
Randy C.
Old February 10th, 2019, 05:27 PM
Thanks for clearing that up. óBilly
Billyaxe is offline
cainsriver
December 29th, 2018 06:35 PM
oldspackrat
May 15th, 2018 07:39 AM
stressed1
January 2nd, 2016 03:47 PM
J-(Chicago)
May 8th, 2013 10:53 PM
orthoK
January 10th, 2012 05:26 AM
Quick Reply: 68 Cutlass 442 mouldings and chrome
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
