My roof has pimples. Weird!
Old October 5th, 2017, 06:59 PM
a-merry-can's Avatar
Hi guys,
i DA-ed the roof on my 68 tonight and noticed there are at least 20 or more of these little metal zits on it. The center is raised above the original metal
line, and they all have a recessed ring. I'm planning on grinding them down with an angle grinder, but was just curious if anyone else has seen these on their vinyl roof cars?
a-merry-can is offline
Old October 5th, 2017, 08:10 PM
You sure they aren't hail dings?
oldcutlass is online now
Old October 6th, 2017, 01:44 AM
Del70's Avatar
raised roof....likely the roof got damaged, and a stud welder dent puller was used...
Del70 is offline
Old October 6th, 2017, 03:25 AM
That makes sense, now that I look at it. I guess the P.O. Didn't bother smoothing it out since he put a top back on it. It must have looked horrible!
I'll grind em down and finish sanding. Thanks, guys!
Old October 6th, 2017, 04:06 AM
'87 Delta 88 Royale
rustyroger's Avatar
I dare say many cars that left the factory with a vinyl roof didn't have any attention paid to its finish on the assembly line.
Roger.
rustyroger is offline
Old October 6th, 2017, 06:26 AM
vette442's Avatar
My '72 442 with its 1983 paint job also has dozens of those bumps. They haven't changed in the 17 years I've owned the car. I'll address them when I gets repainted.
Terry
vette442 is offline
Old October 6th, 2017, 08:55 AM
My442's Avatar
Roger.
The roof pillars were finished on the "lead line".
Cars with vinyl tops got a quickie lead job and no finishing.
That it what I saw when I worked at a GM plant in 1972.
The "lead line" was the worst job in the plant. Most of the folks who worked there ended up with lead poisoning.
My442 is offline
Old October 6th, 2017, 10:28 AM
oldolds88's Avatar
late 70s and 80s olds didn't get lead under the vinyl top,unless it had to be repaired. they got a plastic filler,not bondo,some other sort of plastic. I did the lead work on the lansing line. also was a metal finisher on the line,panels did come in with pimples and dents, if the car was slated for vinyl, didn't finish the roof unless it was real bad,if it was padded top even less attention. don't just grind them off,use a body file(called a vixen file) and the sand with 80 grit disc,then d/a sand with 120 grit.
oldolds88 is online now
Old October 6th, 2017, 07:16 PM
cherokeepeople's Avatar
pretty much.my 66 chevelle had a vinyl top which will not be going back on.and they actually finished the lead pretty good on the roof to 1/4 seem.But there are other imperfections they didn't bother with.and years ago my dad worked in a caddy,olds pontiac dealership.and ended up with one of those files,which i still have and use,man that thing is awesome,mows it down with a couple passes.one of my favorite body tools.
cherokeepeople is online now
Old October 8th, 2017, 12:31 AM
Gerald Nickels's Avatar
Post a pic of the tool.
Gerald Nickels is offline
80_Olds_Guy
August 1st, 2013 08:00 AM
oldsdroptop
June 2nd, 2009 07:03 PM
cisco88
July 6th, 2008 04:03 PM
chadnum1
April 30th, 2008 11:12 AM
1BAD68"S"
Brakes/Hydraulic Systems
November 17th, 2006 04:20 PM
Quick Reply: My roof has pimples. Weird!
