Shimming hood
Old March 15th, 2016, 08:01 PM
woodie582's Avatar
Shimming hood
Is it acceptable to shim between the hinges and hood. Both rear corners are low in realation to the fenders. Installing the inner wheel wells changed the alignment. Thanks
woodie582 is offline
Old March 15th, 2016, 08:14 PM
oldspackrat's Avatar
It is acceptable & more common than you might think. I have seen many hoods that have had a large short shim at the rear hinge bolt location. If it is vital that you have original parts I might be able to find one in a day or three.
oldspackrat is offline
Old March 15th, 2016, 08:23 PM
I find these on there all the time.
https://www.opgi.com/cutlass/C240503/
oldcutlass is online now
Old March 16th, 2016, 06:24 AM
Those aren't shims. Those are spacers that are used on EVERY Cutlass hood. They fill the gap between the hood hinge and the underside of the hood at the back of the hinge. For some reason, the hinge bracket has a dip in that area, but the mating surface on the underside of the hood is flat. If these spacers weren't used, you'd crush the hinge bracket when you tightened the rear bolt. These are not adjustments, there are mandatory.
The fitment of the rear of the hood is adjusted by loosening the bolts that hold the hinge to the fender and pivoting the hinge clockwise or counterclockwise to raise or lower the rear of the hood.
joe_padavano is offline
Old March 16th, 2016, 06:27 AM
Note the joggle at the rear of the hinge in these photos:
Old March 16th, 2016, 12:12 PM
woodie582's Avatar
Thanks all, and yes mine are missing and crushed.
Old March 16th, 2016, 12:19 PM
Originally Posted by woodie582
Thanks all, and yes my are missing.
Yeah, if you don't realize they are there, they often jump out as soon as you loosen the rear hood bolts and wedge themselves between the inner fender and firewall. Do NOT ask me how I know this.
I'm guessing that's why the repro houses sell them.
Old March 16th, 2016, 03:36 PM
woodie582's Avatar
Thanks for the lesson Joe.
Old March 16th, 2016, 03:40 PM
I knew that most had them but not the why. I always thought they were shims, thanks for clearing that up for me.
Old March 17th, 2016, 09:07 AM
Someone needs to clear it up for me. Those spacers always seemed like an "Oh, $h!t" fix for a design screwup.
Old March 17th, 2016, 10:52 AM
Opgi states
Quote "Necessary for hood alignment For all ’68-72 Olds Cutlass
Rear spacers fit between the rear of the hinge and the hood and are a must-have on all 1968-72 Cutlass vehicles. The spacer keeps the hinge in the correct location for the proper hood alignment. Spacers are approximately 1/4" thick steel and are sold as a pair."
Old March 17th, 2016, 11:44 AM
Opgi states
Yeah, the OPGI website also says this for their headers:
Originally Posted by OPGI
Cutlass Headers, Olds 400-455, by Doug's Headers
NOTE1:
These do not fit Cutlass Supreme.
OPGI's catalog isn't a Chassis Service Manual or factory parts book. The text TECHNICALLY isn't incorrect - these spacers ARE mandatory to use on the hinges that have that offset in the attach flange. I take exception with the term "shim", however, which implies adjustment. There is no adjustment here. You MUST use the spacers. I put these in the same category as the PS pump bracket spacers, for example. Those aren't "shims" either.
Old March 17th, 2016, 01:08 PM
m371961's Avatar
Never heard the term"joggle" as a noun. Is this a aerospace term?
m371961 is offline
Old March 17th, 2016, 01:18 PM
Chevy budget Olds powered
coppercutlass's Avatar
Are they needed for 72?
coppercutlass is offline
Old March 17th, 2016, 01:29 PM
Yes, actually. It refers to an offset, usually in a machined or formed part.
Do your hinges have a joggle?
Old March 17th, 2016, 01:50 PM
Idk I asked because I never paid attention and I have my hood lined up pretty good. Lining up panels on new cars is cake walk compared to old cars. The level of adjustment is beyond what modern cars have. I guess we have better tolerances in manufacturing nowadays.
Old March 17th, 2016, 01:54 PM
Again, those spacers aren't for alignment, they're to prevent crushing and distorting the flange on the hinge. And yes, manufacturing tolerances are a lot tighter now.
Old March 17th, 2016, 01:59 PM
I missunderstood what they where for.
Old March 17th, 2016, 04:15 PM
m371961's Avatar
Thanks Joe, you always teach me somethin.
m371961 is offline
Old March 23rd, 2016, 06:10 PM
woodie582's Avatar
Well installed driver side spacer and tightened bolt no problem, pass side not so good, bolt is stripped. I assume from painter torquing the bolt without the spacer. Any thoughts on possible fixes without removing hood.
Old March 23rd, 2016, 07:39 PM
Mine broke out so I welded a nut in mine before it got painted. You might see if yours can be tapped to a larger diameter bolt, perhaps metric.
Old March 23rd, 2016, 08:08 PM
Re thread to a slightly bigger metric size. Some would hate the idea but it's the easiest cheapest fix.
Old March 24th, 2016, 03:58 AM
rcktdoc's Avatar
I have helicoiled them
Greg
rcktdoc is offline
Old March 24th, 2016, 05:51 AM
Greg
^^^This. If the nut isn't broken out, install a helicoil.
Old March 24th, 2016, 08:31 AM
woodie582's Avatar
Nut is not broken out. My thought was to try the repair with the hood on, there is 4" of clearance hood to spring.
Old March 29th, 2016, 05:27 PM
woodie582's Avatar
Heli coil in, spacer and bolt tight. Thanks all..
Arrowstorm
January 27th, 2015 03:38 PM
chasman414
February 11th, 2013 10:43 PM
georgiaboy697
July 2nd, 2010 09:23 PM
Gary Lagacy
September 20th, 2008 01:35 AM
scubastever
June 25th, 2008 11:33 AM
Quick Reply: Shimming hood
