U-Jamb Seal Fit Issues
I had full quarters installed on my 71 Cutlass convertible and am in the process of installing the interior. The sheet metal up at the top of the jamb where the U-Jamb weatherstripping mounts does not have crisp edges as the factory did.. The distance from the U shapped cutout in the metal to the inner lip is considerably smaller than factory. So small in fact that I can't get the U-Jamb weatherstripping to fit. Would have been great if I had figured this out before paint but now I am at the point where I need to tweak the rubber. Bought Metro brand. Would SoffSeal or Steele be any better? Anyone crossed this bridge?
I will be keeping this thread in mind though. When I take my car apart to do the PW I will be changing all the fuzzies, putting in new glass and replacing the 1/4 glass seals. Hopefully you will have this issue resolved by then
I looked at Metro
and this looks identical to the parts I put into my Cutlass S.
Take a look at Supercars Unlimited or Steele Rubber. They might have something you can work with better
I had to modify my U-seals even to mount on a factory car. Had to cut rubber in places and open the screw holes. The right side quarter is a bit different then the left - not sure how, but more mods were needed on that side. Door latches differently there, too...
Don't know if this will help you, these are the replacements I put in years ago. Sorry, nothing's been cleaned from all the work done in the fall. I didn't have to modify anything - they just screwed in. The metal insert in the seal did make it just a little hard to screw in though.
Allen, yours look different than the ones I have. It appears that the rubber wedge at the top is thinner and softer. The rubber on mine is very hard and the metal inserts make it difficult to manipulate. What brand were they?
Trimming to get these to work on my setup would probably mean exposing those steel inserts. That concerns me.
Here are photos of my quarters and the rubber I have now. As you can see there is nothing in the way of sheet metal on the inside. On the one quarter the screw hole isn't even on the primary surface.
BTW... Just so you know I'm not nuts, the brown windlace is just for the fit test. Its not my color plan
That's exactly how mine looked to when I took the inner trim off. The sheet metal can be flimsy like you say, but that's why the rubber seal has steel inserts to stiffen everything up. I know you're just doing mock ups right now to see how it fits.
I'll watch your thread to see what happens. Wish I could tell you what the brand was - it's been too long since I put it in. Truth be told I didn't care about the brand as long as it fit. Once installed I promptly forgot it.
Take a look at Steele Rubber Products and Supercars Unlimited. They both have really good quality parts that they claim will fit perfectly. Fusicks has them for 23.50/set. They are the same part for all 72 Olds 2dr A bodies.
tmaleck
August 15th, 2021 08:17 AM
Del70
July 16th, 2011 09:59 AM
71 Cutlass Convertible
December 10th, 2004 12:18 PM
