A Pillar Drip Rail
I'm referring to the piece that the stainless clips over. I have some A pillar rust to repair. I have to weld in the patch and if I could remove this would make the job easier. It appears to be held on by 3 screws, but won't budge after removing the screws. Will send a pic when I can get one if needed.
No need for pics yet - I've pulled one of those and it didn't take any cutting, etc from what I remember. There may be chaulk underneath it (b/n the "topside" of that piece and the actual A-pillar metal) that is keeping it well stuck in place.
After talking with another buddy of mine today that has also pulled these....he agrees....the factory chaulk is pretty good stuff and will hold it on fairly stubbornly even after removing the screws. The factory typically chaulked or sealed up a lot of pieces like this to prevent water leaks which would have been a customer service nightmare if they hadn't.
You might try getting under an edge with a very sharp/stiff putty knife and tap on the knife to see if you can start separating it.
chrisneu68olds
November 17th, 2014 06:16 AM
auto_editor
October 18th, 2013 11:36 AM
