Convertible top pump install trick?
Old July 31st, 2014, 06:11 PM
Tom442's Avatar
Besides a little lube job, is there a trick to getting those three pointy grommets to go down into the bracket? And no hair wisecracks please
Tom442 is offline
Old July 31st, 2014, 08:11 PM
Texas69's Avatar
First, put a little oil on the grommet. Then, if they are like my grommets, stick a small, blunt tipped object in the small hole on the top side of the grommet as you insert the grommet into the hole. This stretched the grommet and helped push it through.
I used a small drift punch. Do not use a nail or other sharp object since it will just puncture the grommet.
Texas69 is offline
Old August 5th, 2014, 06:31 PM
Raysin's Avatar
Smile Installation of pump
I used silicone spray and a 3/16 ball nose Allen wrench and was done very quickly.
Raysin is offline
Old August 11th, 2014, 08:55 PM
Tom442's Avatar
You are correct sir!
Plenty of silicone spray and a little rotational action and they popped home.
Tom
Tom442 is offline
JpMotorsports
June 26th, 2015 03:37 PM
viper771
November 12th, 2011 03:38 PM
gearheads78
July 22nd, 2011 08:54 AM
OLDSRALLYE350
October 31st, 2010 12:32 PM
Barneyo
February 8th, 2008 05:18 AM
Quick Reply: Convertible top pump install trick?
