1970 W25 aft hood is raised (fitment issue)
I have been struggling for some time trying to get the left aft corner of my hood to close flush with the fender when closing the hood. The hood will simply push down into place, but when shutting the hood it always tends to be elevated on the drivers aft side. I have seen other cars on the show field have this problem as well, and it makes me wonder if it is a common problem and if so what is the corrective action. My doors are fitted as near perfect as an A body gets as are the fenders. If anybody can share their situation, I would very much appreciate the insight!
I have never used this company, but someone told me about them. http://www.hoodhingerepair.com/
I am using original springs as my hood is an original hood with the steel frame. There was a thread on here recently about someones hood that wouldn't stay up, and they figured it was because the person greased the hinges.
Lubing the hinges won't be any reason for the hood not staying up, simply makes it easier to open and close. Use a good sprayable lithium as maintenance. Funkwagon, if your interested I have a very nice set of original hinges that I'd be willing to part with. PM me if interested.
Funkwagon you may also just try to lube the hinge with the lithium as I described above. If the hinge joints are binding it may result in exactly the way your hood is acting. It is always the drivers side rear that has problems first and lubing the pivot may give it just enough movement to close flush and won't cost you but a couple of bucks for the can.
It is a Thornton hood, either II or III gen, but I am certain that my OE hood would do the same. The hinges have been cleaned and lubed very well, that should not be an issue but if they are just worn then it would not matter. I'll do some research on the bushing option and reply back later. Thanks for all of the help.
No, There are no clearance issues, as mentioned it simply pushes down and stays if you palm it down. I would prefer to fix it right though. I suspect the hinges are just worn after only 44 years of use. I've sent a quote request to SMS and am waiting for a reply.
I would like to go the SMS route but am not wanting to make the painter wait the 3 week overhaul turnaround plus shipping time. In the interest of moving forward I called Fusick and ordered new springs and the last right hinge they had. The left side is on backorder until August. My right side combined with weak springs were what was giving fits. So we will soldier on and once the car has been removed from the chassis, I'll send my old hinges out to SMS.
RATCHETMASTER
January 13th, 2012 07:54 AM
