Remote Mirror with Code "6-DMI-8"
Old February 23rd, 2014, 05:08 PM
NJ442's Avatar
Hi All. I bought a remote mirror for my '68 4-4-2. It's in pretty good shape. There is a code on the bottom of the mirror itself "6-DMI-8". Is this an original mirror?
The mirror on my car now does not have a code on it...is it a repo? (It has a stray drill hole in the base so that is why I decided to replace it).
Thanks for your help,
Paul.
NJ442 is offline
Old February 23rd, 2014, 07:44 PM
Randy C.
rcorrigan5's Avatar
As I understand, the mirror you bought has a date code of June (that's the "6"), 1968 (that's the "8"), so it appears to be an original mirror for a late production '68 "A" body, or possibly even an early production '69 model "A" body. I would say the reason the mirror on your car doesn't have a code on it is because it is a replacement mirror.
Randy C.
rcorrigan5 is offline
Old March 4th, 2014, 05:19 PM
NJ442's Avatar
1968 Remote Mirror Base - 2 Holes from the factory?
Thanks for your help. One last question please - it appears that on the base of the mirror there are two holes that look like drill holes (without the screws). When you look under the base, you see a plug in each opening. The reason I bought a second mirror was because I thought someone drilled screw holes in the base in error. Can you tell me if that how the mirrors were made at the factory - with 2 holes in the base?
Thanks,
Paul.
NJ442 is offline
Old March 4th, 2014, 07:36 PM
Randy C.
rcorrigan5's Avatar
If you are talking about the two holes on top of the base that go through to threaded holes on the bottom side, yes, those holes are supposed to be there. The two screws that hold the mirror to the door come in from inside the door panel, through the door and into the threaded bottom side of the base. Those screws have a hex opening on the threaded end. The screws are tightened by using an allen wrench through the holes on the top side.
I think that is what you are talking about.
Randy C.
Old March 4th, 2014, 07:50 PM
Texas69's Avatar
Also note that the threaded hex head screw uses a reverse thread from the vantage point of the mirror base top. In other words, when tightening the screw with an Allen wrench, you must turn counterclockwise.
Texas69 is offline
nitrojunkie1029
Tech Editor's Desk
November 2nd, 2011 01:38 PM
81 regency
April 21st, 2011 06:18 PM
70redvert
August 21st, 2008 08:29 PM
cincyDelta
June 24th, 2008 10:57 AM
rrielley
February 9th, 2008 10:43 AM
Quick Reply: Remote Mirror with Code "6-DMI-8"
