What is this called?
The guy I bought the car off of said someone backed into the grill and tore it up. What is this support called. Hood latch support? Stone guard support? I've looked up several different things with no luck. Is it separate from the core support or is it part of it? I'm looking for one for a 72 if anyone has one or knows someone.
#39: Support, Hood Latch (welded), or
Hood latch support, '70-'72 F-85, #406862.
As the description states, this piece is welded to the core support, which explains some uncertainty as to whether it is all one piece or not.
39 is called the hood latch support and it's welded to the core support. That's what it says in the GM Parts manual. Group 8.080 Part 406862. Like I said earlier - I haven't seen it as a reproduced part.
Anytime. Seeing as you're in OH you're right next to 2 guys who can likely help you. Send one of these guys a PM, they both part out these cars. Most often the battery tray area is rusted out or the car has been hit on one side leaving that center brace very usable - just needs to be cut out. Those supports are the same for 71/72 Cutlass models, regardless of being coupe, sedan or wagon.
jensenracing77 - Eric - in Brazil, Indiana
oldspackrat - Scott - in Indianapolis, Indiana.
Have a look at this 72 core support listed here on the site for 100.00. Maybe you could get him to cut out and send just the section you need?
I'm not a bodyman, but your picture shows a piece that is just bent, not missing or rusted through. Seems to me a competent bodyshop could remove, straighten, and repair that piece to like new condition....
Yes, it's bent and it's ripped. It's bad enough that I would have about the same amount of money having someone "try" to fix it and hope that everything lines back up and fits, as I would if I just found one and replaced it myself. The car is just going to be a daily driver but I don't want to fight with trying to get the stone guard and everything lined back up.
oldsmohaulic
December 18th, 2009 11:02 AM
Col Wickham
November 19th, 2009 04:58 PM
