how to remove a dashboard
Old January 2nd, 2014, 08:19 PM
spyke's Avatar
I'm trying to remove my dash so I can wrap it with some vinyl anybody got any directions
spyke is offline
Old January 2nd, 2014, 08:29 PM
2blu442's Avatar
From your previous posts I think you've got a 1970 Cutlass. If so, check out this thread and let us know if you still have questions about any of the steps.
John
https://classicoldsmobile.com/forums...2-cutlass.html
2blu442 is offline
Old January 2nd, 2014, 09:25 PM
Something you should take into account is it will take some time to remove the dash pad. The dash insert is also bolted to the dash pad. If your car has AC then accessing the nuts on those studs can be a real PITA. Just work slowly and methodically. Take pics as you go just in case.
When I pulled the dash from a 71 CS at the boneyard last year I found that pulling the harness and AC controls at the same time made the job go a lot faster. Less things to undo. Note that in some of John's linked pics that's what he has done also.
Allan R is offline
KRICHEN922
July 1st, 2010 09:17 AM
The_Jeremiah
December 20th, 2007 11:31 AM
slipbakka
May 8th, 2007 03:21 AM
Phils85
March 16th, 2007 04:40 AM
carfreak
October 17th, 2006 09:27 PM
Quick Reply: how to remove a dashboard
