1964-1965 88 Parts Interchange
Old October 10th, 2012, 12:05 PM
bills65olds's Avatar
Would a front bumper, rear bumper, and hood on a 1964 Oldsmobile 88 be the same as the '65's?
bills65olds is offline
Old October 10th, 2012, 02:59 PM
jaunty75's Avatar
You can answer this for yourself if you just google images of these cars.
Here's the rear bumper on a '64:
and here's a '65
It's obvious that they are very different.
Front bumpers are no better. Here's a '64:
and here's a '65:
The bumper on the '64 is completely horizontal, while that of the '65 is more sculpted and dips down around the headlights on each end.
These latter two photos show that the hoods won't interchange, either. On the '64, the leading edge is completely straight all the way across, while on the '65 it bends upward to wrap around the headlights. There are other differences as well.
For all the similarities these cars have in that era, there are often subtle differences from year to year that make body and trim parts not interchangeable.
jaunty75 is offline
Old October 10th, 2012, 06:06 PM
Lt. Buzzkill (ret.)
copper128's Avatar
Virtually nothing is the same between the 64 and 65 full size Olds. GM did a complete redesign of it's B & C-body cars for 1965, including everything from the chassis to the sheetmetal and darn near everything in between.
copper128 is offline
Old October 18th, 2012, 02:49 PM
I found a '65 Olds 98 sitting in a local wrecking yard. The rear bumper is different however the front bumper and hood look identical. Are the parts the same?
Old October 18th, 2012, 03:14 PM
jaunty75's Avatar
Typically, for the full-size Oldsmobiles, 88's and 98's were identical from the firewall forward, so, yes, I would expect that the front bumper and hood from a '65 98 would fit fine on a '65 88.
jaunty75 is offline
Old February 11th, 2017, 01:11 PM
Mroldsmobilefrommass's Avatar
None
Pretty much nothing from a 64 will fit a 65, With the exceptions of Dist cap, points ETC. Engine, trans,body, ALL re done. I'm sure by now you have all this figured out. YES, a 88/98 hood/ front bumper is the same. # 589751 ft,bar and 386011 hood.
Mroldsmobilefrommass is offline
Old February 11th, 2017, 03:51 PM
This thread was from 2012, so hopefully he got the answer already.
joe_padavano is offline
JATA
September 23rd, 2013 04:58 AM
BeenThere
March 1st, 2013 05:57 AM
jon1957
Brakes/Hydraulic Systems
April 11th, 2012 11:47 AM
Jetstar 88
Drivetrain/Differentials
16
March 15th, 2012 06:21 PM
Sumner
December 13th, 2010 02:12 PM
Quick Reply: 1964-1965 88 Parts Interchange
