Removing hood trim 68 442
Old June 10th, 2016, 01:10 AM
louie's Avatar
I have everything removed except the full chrome piece at the top of the hood at the windshield, any tips? Seems very tight.
louie is offline
Old June 10th, 2016, 06:14 AM
Randy C.
rcorrigan5's Avatar
It is pretty tight - just held on by friction. I used a piece of hard wood shaped like a paint stirring stick and tapped on the underside of the stainless strip across the underside. Just worked across and back until it finally released from the hood.
Randy C.
rcorrigan5 is offline
Old June 11th, 2016, 04:08 AM
louie's Avatar
Thanks! Worked great with no damage.
louie is offline
Old June 11th, 2016, 06:52 AM
Randy C.
rcorrigan5's Avatar
You will have to be a bit more physical with it when you put it back on...again, I used a piece of wood to help it back onto the metal lip and it worked fine without marring or otherwise damaging the stainless.
Randy C.
ToroToro
Body work
January 28th, 2011 11:28 AM
desert442
Body work
May 10th, 2009 10:47 PM
jensenracing77
February 23rd, 2009 04:19 PM
RWB
December 10th, 2007 04:58 AM
cutthroat
May 14th, 2007 02:39 AM
Quick Reply: Removing hood trim 68 442
