Tailgate window setting up
Old April 3rd, 2018, 12:33 AM
skippy's Avatar
Need some advice. Just fitted replacement used parts for the electric tailgate window on my 65 Vista. When I bought the car the only thing there was the glass. Its now all fitted and working but with one issue, the glass gets to about 2 inches from the top then stops, every time. Initially thought it was a motor getting hot but the window will go down OK and back up to the point it stops. Cant see any restrictions but cant get my head round why its doing it. Any help and advice gratefully received. Not sure if my buddy has set it up correctly as cant find any info on set up.
skippy is offline
Old April 3rd, 2018, 11:26 AM
jimjific's Avatar
Can you tell if the gear has reached it's limit or stopping point?
Jim
jimjific is offline
Old April 3rd, 2018, 01:52 PM
skippy's Avatar
Not sure, it seems like it but not sure how to tell and where the stop is
skippy is offline
Old April 4th, 2018, 01:02 AM
skippy's Avatar
I'm not convinced that the side channels are in the right way, there was nothing there at all other than a window. Really need to see decent pics of the set up as cant really tell from the workshop manual drawings. My buddy is taking it out again later this week and try to figure it. The runner on the side of the glass is far too tight as it gets to the top of the side channel.
skippy is offline
Old April 4th, 2018, 04:52 PM
Yellowstatue's Avatar
If the motor isn't mounted to the gear in the proper spot, then it will run out of teeth. There is a post on this forum addressing this problem. Search around.
Yellowstatue is offline
Old April 5th, 2018, 01:03 AM
skippy's Avatar
Just spend 30 minutes while at work searching for the thread but cant see it, anybody got a link they can post I'd be grateful
skippy is offline
Old April 5th, 2018, 06:40 AM
jimjific's Avatar
One other thought I had is did you try extending the window with the tail gate down or slightly opened? This would tell you if it was the gate or car track issue.
Jim
jimjific is offline
Old April 5th, 2018, 06:53 AM
skippy's Avatar
Yeah I have tried it with tailgate slightly open and it stops in the same place, so guessing issue is in tailgate
skippy is offline
Old April 5th, 2018, 07:07 AM
jimjific's Avatar
Sounds like the motor is sunning out the window gear too soon.
Jim
jimjific is offline
Old April 5th, 2018, 07:49 AM
skippy's Avatar
I'm suspecting that, has anyone got a pic of motor/gear with the window fully up so I can see how many teeth are left exposed.
skippy is offline
Old April 7th, 2018, 05:01 AM
68442's Avatar
Check the window channel for rust/rot. This is the horizontal item the window is set/glued into. I have run into this a few times with the vista's. If rust/rot gets into the channel and expands it , even a little, it will stop the travel to the top. basiclly hits the upper frame. Very narrow.
68442 is offline
wyteon
Vista Cruiser & Wagons
November 30th, 2018 11:33 AM
danlonchar
August 31st, 2017 08:18 AM
Longroof
February 19th, 2010 06:11 AM
efitzor
January 26th, 2010 08:39 AM
stlbluesbrother
November 23rd, 2009 08:56 AM
Quick Reply: Tailgate window setting up
