Square Nuts for inner fender & hood hinges and radiator support
Square Nuts for inner fender, hood hinges & radiator support 66 Olds 442 & others
If you are looking for the inner fender nuts that are used on 66 Olds Cutlass/442 that are pressed in when the fender and other parts are stamped out, I finally found a source...
They are called 5/16" Pierce nuts...
The supplier is AMK products website WWW.AMKPRODUCTS.COM
The part number is B-10558 sells 6 nuts for $4... minimum order is
$30 plus shipping....
AMK is an automotive fastener supplier for low quantity items, I will be using their
415 page catalog quite a bit. You will receive the catalog on your first order.
Please respond to me if you found this helpful... Bill Lewis
There are ususally Fastener or Bolt stores located in most cities. Auveco also carries a wide variaty of specialty fasteners and the bolt stores may have these items in stock where you won't have to meet the $30 minimum + freight.
Bill I found this very helpfull as I was looking all over for these pierce nuts! Thank you for posting this great resource!!!!
Drew
georgiaboy697
July 2nd, 2010 09:23 PM
