Air cleaner seal
Old April 25th, 2019, 09:09 AM
jmcghee's Avatar
Air cleaner seal
How do you mask the seal when you paint an air cleaner? I have seen them just painted over But the paint flakes off. Not good
jmcghee is offline
Old April 25th, 2019, 09:34 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Ya should never paint the seal.
I usually just pull the old seal out and replace it with a new one. Masking for me would be too tedious.
Does the underside really need paint? If its in good shape, not rusty whose gonna see it.
droldsmorland is offline
Old April 25th, 2019, 01:09 PM
MOTORHEAD
11971four4two's Avatar
I wiped the seal with lacquer thinner on mine. then used 1/2 inch tape to mask it off. The edges i pushed in with a flat blade screw driver and some trimming with a razor blade to the tape
11971four4two is online now
Old April 25th, 2019, 08:10 PM
jmcghee's Avatar
thanks for the answers guys. Previous owner bead blasted the air cleaner, its bare naked!!!! I will look for a new seal
jmcghee is offline
Old April 26th, 2019, 07:30 AM
Lance
ROCKET VAPOR's Avatar
SoffSeal SS-2099
https://www.soffseal.com/ss-2099
ROCKET VAPOR is offline
Old April 26th, 2019, 09:49 AM
For sure Softseal is one of many reproduction vendors that offer this gasket. Put "air filter lid gasket 68 Oldsmobile" in your Googler.
Old April 26th, 2019, 02:39 PM
MOTORHEAD
Prime and paint the lid before you install the new seal
Napoleon Solo
May 16th, 2017 11:13 AM
Oldssupreme
August 3rd, 2016 06:12 PM
Inline
Body work
March 31st, 2016 09:18 AM
1970VistaCruiser
August 28th, 2013 07:29 PM
jdana24
May 18th, 2011 04:03 PM
Quick Reply: Air cleaner seal
