Go Back  ClassicOldsmobile.com > Repair & Restoration > Body & Paint
70 Cutlass S Front fender script: How do you change it? >
Old May 15th, 2017, 08:06 AM
Sportcoupe's Avatar
Hi there! Greetings from Spain,
Iīm a newbie in this forum but not in the classic car passion, as I have been owning and restoring classic cars for the past 10 years. One month ago I bought the jewel of my garage, a 70 Cutlass S. You can read the story of the car here: https://classicoldsmobile.com/forums...k-hardtop.html
The car is in an exceptional condition for a car this age; it drives and runs great. Everything works, even the clock, except for a couple of small details I would like to solve to bring it back to its pristine condition.
One of them is a broken "Cutlass" fender script. I bought a new one but when I try to change it I see there is no access by the inside of the fender, as the inner fender prevents my hand to reach the nuts. Access by the rear edge of the fender opening the door seems very difficult and I canīt see access from the engine compartment, partly due to the tubes and valves of the A/C system.
I checked the body manual but I couldnīt find any help on this issue. Does someone know which is the best way to acess the script nuts by the fender interior?
Here you can see the broken script
Thank you in advance
Sportcoupe is offline
Old May 15th, 2017, 11:40 AM
jensenracing77's Avatar
Pulling out the inner fender is the easiest way but you have to be careful sometimes. The 4 bolts around the wheel opening often are rusty and will rip out the plastic of the fender liner. You can get to them with oil from under the hood but is hard to get to them. Also with that being a 70, the nut clips have hex heads on the clip that you can put a wrench on to help from ripping out the plastic.
jensenracing77 is online now
Old May 15th, 2017, 02:13 PM
The absolute best thing to do for emblems is to use barrel nuts.
That allows you to take the emblems off and on easily, without the hassle of the sheet metal nuts that the factory used.
My442 is offline
Old May 17th, 2017, 04:37 PM
Sportcoupe's Avatar
Thank you for your answers, guys, itīs not an easy job but now I know the path to take
Old May 18th, 2017, 03:05 PM
Oldsdruid
Put a couple layers of masking tape around the script to protect the paint, and get a SHARP stiff-bladed putty knife. Carefully put the knife-edge behind the script at the mounting studs. Then push or tap downward on it and shear off the original emblem studs.
Use barrel nuts to attach the new script.
rocketraider is offline
Old May 19th, 2017, 04:48 PM
Sportcoupe's Avatar
Thank you for your tip, rocketraider. Seems an easy way to solve the problem. I didnīt know about barrel nuts. I think they are like these:
Thereīs only one problem: They seem easy to find in USA, even on Ebay.com but in Spain, where I live, I havenīt been able to find them so far. I can buy them from Ebay but shipping costs are far higher than the barrel nuts pack... Iīll go on trying to find them locally or try removing the inner fender. If this proves to be too difficult Iīll order them from U.S.
Old May 19th, 2017, 06:17 PM
But you will still have to remove the inner fender to get the broken one off.
Old May 21st, 2017, 09:36 AM
Sportcoupe's Avatar
Well, thatīs option #1... The other option is shearing off the original emblem studs as rocketrider has suggested... The only drawback is that the studs will be allways there, maybe rattling inside the fender... I think thatīs what you are pointing out.
I think I will try to pull out the inner fender following your advice... If it turns out to be too difficult I will following rocketriderīs tip...
Thanks a lot to all of you, guys... Iīll keep you posted about the results
Old July 16th, 2017, 11:45 AM
Sportcoupe's Avatar
Hi there,
finally a friend who helped me with all the fixings that the car was needing suggested using a nylon thread to take the old broken script... And Pop! Out it went quick and easy... The remains of the old script were stuck to the body with double sided adhesive tape.
The new one was attached with 2 nuts through the door access to the inside of the fender with delicate touch to place the nut and a small ratchet wrench.
Under the old script there were small chips surely caused when someone tryed to pull off the script (see the pic below). We fixed them with a small brush before installing the new one and now it looks great, as you can see on the pics:
Thank you all for your help and support!
Next body intervention: Repaint the "S" emblem with the proper paint
Old October 29th, 2017, 12:01 PM
olds 307 and 403's Avatar
Awesome, I will be removing mine shortly, tells me what I need to do. Helpful thread.
olds 307 and 403 is offline
68RocketAction
January 26th, 2016 08:28 PM
Ronschwartzsr
April 1st, 2014 01:40 PM
dre
Drivetrain/Differentials
August 31st, 2011 11:04 AM
tness
March 19th, 2010 07:21 AM
Quick Reply: 70 Cutlass S Front fender script: How do you change it?
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
