68 442 convertable rear molding
Im in the process of installing the molding that runs along the rear of the vehicle around the convertable top, when installing the molding i notice near the quarter window there are holes to screw in the molding, but in the rear of the vehicle above the trunk lid i see holes in the molding where it seems a screw goes through but i do not notice a hole in the body the vehicle was in a bodyshop and im not sure if the holes were either patched or is there a special clip that is needed thanks for any help that is given
There are special clips that hold the entire molding in place. You can buy repro clips from Fusick - see www.fusick.com - the part number is D3645, convertible belt molding fastener. As I recall, the fasteners are held in place with a screw and then the belt molding snaps onto the fasteners.
Another "as I recall" issue is that there is actually accommodations for some 9, 10 or 11 of those fasteners. But, in during actual assembly, the assembly plants only used 5-6 of the fasteners to hold the belt molding in place.
There shouldn't be any screws that go through the top of the molding into the body.
Randy C.
Randy C.
sx455raidercelticfan
October 8th, 2010 12:13 AM
