65 Cutlass molding clips
Old May 4th, 2018, 12:42 PM
In preparation for painting the passenger door on my 65 Cutlass Holiday Coupe I removed the "Front Door Outer Panel Peak" (Body Service Manual speak) molding by gently hammering it towards the back. This worked fine, i.e. the molding is undamaged, but all clips got destroyed in the process.
According to the BSM, what I need is clips as per View C, which displays so-called bathtub type clips.
Anyone know a part number and where to source these? Do I need an installation tool?
Thanks!
Bremer is offline
Old May 4th, 2018, 01:07 PM
If you are talking about the plastic clips that go over the trim studs, they are made by Au-Ve-Co and just about every resto vendor and clip specialty vendor sells them. They come in a variety of sizes.
joe_padavano is online now
Old May 4th, 2018, 02:30 PM
Thanks Joe.
Unfortunately I don't know what the clips look like in their normal form since all I have are the destroyed ones. However, there are no trim studs, just holes.
The photo shows what I need according to the BSM. Are the clips you posted the photo of the right ones in this case?
Bremer is offline
Old May 4th, 2018, 02:42 PM
Originally Posted by Bremer View Post
Thanks Joe.
I guess I need a photo of the holes. The factory would have used weld-on trim studs that look like little nails. The keyhole in the plastic clips I showed goes over the trim stud, and you snap the trim into place over them. There was usually a screw-on clip at the front and back ends of the trim that went through the door for positive retention. If you have holes, someone has done that.
Alternately, you can use these type of clips with nuts on the back. These snap into the trim first, and the studs go through holes in the sheet metal. Use seam sealer on each hole to prevent water intrusion.
Old May 4th, 2018, 03:02 PM
Thanks Joe. I'll see that I take some photos of what I'm working with and post.
Bremer is offline
Alex72cutty
August 6th, 2012 04:45 PM
317Cutty
June 2nd, 2012 05:15 AM
TenMidgets
January 2nd, 2012 07:13 PM
1968Cutlassfallbrook
December 13th, 2010 06:30 PM
Threejdsolds
December 11th, 2008 09:22 PM
Quick Reply: 65 Cutlass molding clips
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
