Clearing roller rockers?
Old June 25th, 2015, 04:20 PM
Rodney
cdrod's Avatar
Will these M/T valve covers clear adjustable roller rockers on ProComp heads?
cdrod is online now
Old June 25th, 2015, 05:07 PM
Beer Connoisseur
70cutty's Avatar
I have the MT covers and I use sce 179076 gaskets. They are extra thick, it clears just fine. Depends on the poly locks you are using.
70cutty is offline
Old June 25th, 2015, 05:16 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I have the Edelbrock version, same height and they just clear with 1.72 ratio rockers on iron heads. I am using the discontinued Felpro Permadry valve cover gaskets.
olds 307 and 403 is offline
Old June 25th, 2015, 05:47 PM
cutlassefi's Avatar
Just an fyi- Rocker ratio has nothing to do with it. As 70cutty said, if the poly locks are short enough you'll be fine.
cutlassefi is online now
Old June 26th, 2015, 06:35 AM
True enough, I guess Scorpion uses the shorter poly locks.
Old June 26th, 2015, 09:23 AM
Rodney
cdrod's Avatar
Small Poly-locks
Are these the small Poly-locks on my heads?
cdrod is online now
Old June 26th, 2015, 04:46 PM
Those look similar to mine.
Old July 6th, 2015, 09:35 PM
buzzbomb's Avatar
you will need double gaskets with those for sure. I use the edelbrock 1/4" thick ( they are a bit thinner than the 1/4' quote) and glue them to the cover with silicone and glue between the gaskets also and let set till dry. Do not put anything on the bottom and you can use them over and over again. If you have the a/c and alt brackets they will still clear them.
P.S. make sure you use anti seize on the plug threads and remove and install cold.
buzzbomb is offline
83hurstguy
May 3rd, 2015 07:47 PM
junkyard72
December 30th, 2013 07:16 PM
AzChevs
October 8th, 2013 06:26 PM
Vader
August 9th, 2012 08:29 PM
Redog
August 14th, 2008 06:56 PM
Quick Reply: Clearing roller rockers?
