Any tips on cleaning a radiator during an engine swap?
I do have the three pass radiator from the donor car and wondered if there is a good recommendation on flushing the radiator to remove any corrosion while it is out of the car. Any recommendations on a cleaner that won't be too harsh on the brass?
As I am preparing to swap my 330 for a healthy 455, I am trying to get all of the parts organized in advance.
If it's a copper/brass radiator, and it's more than 4 years old, chances are pretty good it will need to be reamed, if places even do that anymore. Most just re-core or replace. Probably better just to cut to the chase and replace it, there's many affordable aluminum ones out there now. Think I paid $265 for my last one and that included shipping. Probably spend at least half that at a radiator shop.
Here starts the MAW's, old radiator with new motor can cause serious problems, somethings are better of being new, may save $$ in long run. Paid radiator shop to check and clean a radiator and after picking it up I could shake radiator and hear stuff moving around. Looked inside with flashlight and it was still dirty and some tubes were partially plugged up. Getting hard to find quality shops.
I was going to try and maintain originality with my car, but found out the rad is a 2 row core and I wanted 3 row. After checking on line prices for copper/brass core 3 rows I almost fell out of my chair. Including shipping that would be close to 500.00 plus tax. So I called some local shops and asked how much to re-core with a 3 row. They all wanted close to 400.00. So now my dilemma is whether to restore or buy new. Originality would be nicer IMO because I'll still have the Harrison tags on the tanks. Nothing is cheap here nowadays. Down side: Will the Harrison tags mean anything after I convert to 3 row? The car survived all these years with a 2 row, so the other dilemma is whether to keep that feature.
Depends on how old it is, I've cleaned two radiators (one an aluminum core, one a copper core) with vinegar and water (doesnt have to be hot water either) and the insides came out nice, lots of crap came out though. You also should shake them with the vinegar/water inside. If it's really old, listen to everyone else, take it to a shop.
Radiator shops typically use ultra-sonic tanks to clean with vibration. It doesn't take very long and is typically followed by a pressure test and soldering of leaks. You should get a clean, test, and repair from any old established radiator shop. They do them all day long and will probably appreciate it if you pay in cash and don't require a receipt.
As I have learned, it does no good to get the radiator reconditioned if the block water jackets are full of corrosion ( it will plug up and restrict the water flow on that new radiator) Make sure you repeatedly flush your engine out with the existing radiator - provided it is flowing at all.
As I have learned, it does no good to get the radiator reconditioned if the block water jackets are full of corrosion ( it will plug up iron restrict the water flow on that new radiator) Make sure you repeatedly flush your engine out with the existing radiator - provided it is flowing at all.
Let me endorse this too. No matter how clean or new your radiator is, if you have a block full of gunk you will clog the radiator in short order.
Flush out/ recore the heater radiator too, and replace the hoses if you have any doubts.
Roger.
Good advice. Flush and clean the system BEFORE you spend the money to rebuild the radiator. That way you don't fill the repaired radiator with debris from the engine.
I took my rad to a shop here they opened it up and rodded it out $75. After my block was machined i noticed crap falling out of the water jackets when upside down on the engine stand. I took a long flat blade screw driver and scraped literally almost 2 pounds of crud from them. Now some of the weight of that was probably oil that got in while machining the block as all the crud was moist but it filled 2 inches across a gallon size zip lock bag. Most of it was fairly loose in the water jackets, that would have eventually ended up in the radiator. It took about an hour and a half to clean both side water jackets but now i can see all the way to the bottoms. I also flushed them with high pressure sprayer after all the scrapping. Clean as a wistle.
Steve
Steve
With apologies to the OP for jacking this thread slightly.
Must be a regional thing or your shop has a really low hourly rate. Or sometimes I swear they see me coming or maybe it's just I say 65 Cutlass and they tack on an extra 20%.
That is alot of good advice
Thank you for all the tips guys, I will heed the advice. I found a local, old time radiator guy to have a look at it to see what the radiator needs. Now I need to plan to flush out the block, missing this detail does seem like a silly mistake. I started removing the old heater core tonight, so I am sure the new one will be clear. I do see some scale in the water pump, but the cooling ports were clear when I had the intake off; at least as far as I could see.
Lets see how the rad shop visit goes, I may have a contact to recommend to the folks in Pa.
Thanks for sharing the years of experience.
Larry
Larry
Is the 66 core support the same for a 67? I put a Suburban aluminum radiator in my 67 461. drops right in and the motor runs very cool. 150-180 thats it> If you interested I can you provide you more detail.
adpostel
December 1st, 2010 08:58 AM
1970455sx
November 28th, 2010 03:58 PM
