Does anyone know if this is a oil pump to main cap gasket?
Old July 1st, 2013, 03:50 PM
Al2011's Avatar
Hi everyone!
Got a question. Is the gasket in the link below for the oil pump to main cap? My engine is Olds 455.
http://www.summitracing.com/parts/fel-13458/applications/make/oldsmobile/engine-size/7-5l-455
If i don't use a gasket do I just bolt the pump without any sealer or what sealer should I use.
Below are two other gaskets I found but not sure if any gasket is required.
http://www.schumannsdynamicperforman...ng-gasket.html
http://www.mondellotwister.com/PB-300.gif
Al2011 is offline
Old July 1st, 2013, 04:16 PM
gregvm's Avatar
No, that summit gasket is the oil pump housing to oil pump cover gasket.
No gasket/sealant is needed for oil pump to main cap mating surface
gregvm is offline
Old July 1st, 2013, 09:20 PM
64Rocket's Avatar
that is a oil pump to main cap gasket, with the oil pump pick up to oil pump gasket.
The gasket for the pump to main cap is a very thin copper gasket. I have seen one, but have not use it yet. Something new that some one think is needed.
From the factory it is metal to metal, no gasket used.
Gene
64Rocket is offline
Old November 19th, 2013, 04:47 PM
ZATBAD 72
joades's Avatar
I just saw this thread and have the same question on the 455 I am building. My gasket kit came with NO pump to main cap gasket. My shop manual is no wealth of information on the topic. Is the pump to main connection truly metal to metal? Would obviously leak but seems to me it would be so minimal that it could not affect the oil pressure.
joades is offline
Old November 19th, 2013, 05:18 PM
Octania's Avatar
Leak?
To where? The oil pan?
Certainly not enough volume in such a leak to affect the pressure in the engine.
The factory engineers did not use a gasket there.... hint, hint.
Octania is offline
Old November 19th, 2013, 06:34 PM
The oil pump to main cap doesn't use a gasket, nor is one needed. The surfaces are both machined flat, there is no place for oil to leak. The mondello part is baffle to keep oil from climbing up the back off the oil pan. It just happens to use the pump to cap mounting surface as a place to bolt it in. If a gasket was needed you can be sure the Olds engineers would have included one.
matt69olds is offline
Old November 20th, 2013, 07:15 AM
Run to Rund's Avatar
Just bolt the pump onto the cap. No reason to worry. You are falling victim to the mantra "there is no end to concern."
Run to Rund is offline
costpenn
August 29th, 2018 11:42 AM
krooser
January 17th, 2013 10:15 PM
trackz man
July 17th, 2011 10:08 PM
IDAS 69
March 1st, 2009 06:05 AM
esisson
November 17th, 2008 05:39 PM
Quick Reply: Does anyone know if this is a oil pump to main cap gasket?
