Evans Waterless Coolant
Old June 6th, 2013, 08:04 PM
Don Roberto's Avatar
Hi! Has anybody tried Evans Waterless Coolant? Jay Lenons uses it in his cars and recommend it for classic cars. It will not correct cooling problems but I feel that for slight idling overheating it would be an option.
http://www.evanscooling.com/
Don Roberto is offline
Old June 6th, 2013, 08:19 PM
Although it has a higher boiling point is higher, the temp is still going to effect your engine and trans. It looks to be a good product but it will not solve an over temp problem.
oldcutlass is offline
Old June 6th, 2013, 08:23 PM
Yeah. It seems that any overheating problem should be resolved before using this product.
Old June 7th, 2013, 08:19 AM
'87 Delta 88 Royale
rustyroger's Avatar
If you fix your idling overheating problem properly regular 50% antifreeze mix should be all you need.
Otherwise any cooling fixes will be band aid solutions, give us more information about your car and we can help resolve any issues you have.
Roger.
rustyroger is offline
Old June 17th, 2013, 05:10 PM
Roger sorry for the delay in responding. I fixed the overheating issue. I had a bad fan clutch. But the Evans also prevent the constant change of antifreeze and since it does not have water, it also prevents engine corrosion. I don't know, I might like to try it at some point. I just added new antifreeze and planning to change it next year. I'll consider it then.
wcourt3010
November 14th, 2014 10:34 PM
oldsonharmont
May 6th, 2014 09:13 AM
dc2x4drvr
March 21st, 2014 07:20 PM
ztim
December 22nd, 2006 10:20 PM
Diabolus
July 23rd, 2004 04:35 AM
Quick Reply: Evans Waterless Coolant
