Long or short water pump?
Old May 16th, 2013, 10:50 AM
"Trying to fix her right"
dfire25's Avatar
Which water pump do I use for a 455 with A/C? So confusing
dfire25 is offline
Old May 16th, 2013, 11:58 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
depends on the year. 71 and later use a 6.1
70 and older use the 5.6
MOST IMPORTANTLY, it depends on your pulley codes as to what will work.
J-(Chicago) is offline
Old May 16th, 2013, 12:16 PM
dfire25's Avatar
I have a 71, not sure about the pulley code. I do have the triple grove pulleys.
dfire25 is offline
Old May 17th, 2013, 09:55 AM
Octania's Avatar
for accuracy you must be sure of the pulley part number or letter codes
clean and read 'em, or measure OD and width and consult my database which is emailed upon request
Chris
Octania is offline
Lars
November 10th, 2013 12:05 PM
65oldsguy
August 29th, 2012 09:50 PM
Al Graaf
June 16th, 2012 09:05 PM
Cobrar980
April 22nd, 2012 05:05 PM
64 CUTLASS KEN
November 22nd, 2010 05:17 PM
Quick Reply: Long or short water pump?
