455 build with pictures and dyno test starts today
#121
The bottom end is machined and ready to assemble, the heads need to have the porting finished and thats the hold up, I just have not wanted to spend the time on it, but it needs to get done.
#122
#123
That engine was built a few years back, it went into a 1970 442 convertible 3.23 gear, fully loaded car with air conditioning, turbo 400. I went with the owner to the track 1 time, he ran 12.06 @ 119 MPH with 275 drag radials in full street trim, 27.80 baro 2130 feet elevation. He was 70 plus years old and became sick and we never got a chance to dial the car in. The car will be for sale in the near future.
#125
Although seeing the car was raced 1 time and we didn't run it across the scales I will just have to guess at the weight, and I can be corrected, I would say 4000 pounds sounds right.
119 mph @ 4000 pounds is 519 observed HP in a 27.80 barometer. Personally I prefer to rate HP from track performance.
Engine build:
Lightened CP pistons, 1.5 1.5 3.0
Eagle rods remachined
Production crank, indexed, stroke set 4.250, counter weights cut .500 total
236 @ .050 hyd roller on a 108
Ported production heads 294 CFM @ peak, 275 CFM @ valve lift 28 inches
Modified production oil pan
Harlan Sharpe rockers
Performer RPM intake
1000 CFM AED carb
ATI balancer
10 inch Coan converter
Turbo 475 strait cut
3.23 gear
Engine build:
1000 CFM AED carb
ATI balancer
3.23 gear
#127
It required no heavy metal. I took a few hundred grams out of the bob weight over the factory set up. I bull nosed the the leading edge of the counter weights, and cut a total .500 off the counter weights. I ended up drilling one small hole on each end of the crank to balance. I do the same thing to the Chevy's.
#128
So you took .500 off the circumference of the counterweights and it still didn't need any heavy metal?
Next time show us a pic of the Olds crank you did, not a Chevy.
And aren't you the one that posted a pic of an "Olds" on a dyno and it was really a BBC? I see old habits die hard
#129
"So you took .500 off the circumference of the counterweights and it still didn't need any heavy metal"
Correct
"And aren't you the one that posted a pic of an "Olds" on a dyno and it was really a BBC"
No...I think you have the wrong person. The picture I put up was an example of how the 455 Olds crank was done.
#130
Correct Bullshyt.
Correct Bullshyt.
I don't believe for a minute that you could take .500 off the circumference of the counterweights of a 455 crank without adding slugs. What was the amount of the final bobweight?
#131
No that was you, its on here somewhere. I'll see if I can find it. The Chevy crank pictured doesn't have .500 cut off of that either.
In the mean time: how do you dyno a BBC and say its a Olds? Keep looking
So the question to the forum, whats better, multiple deep drilled holes in the counter weights, or the counter weights cut and minimal drilled holes?
#133
Neither one. If you had to take that much off you should’ve just thrown a couple of slugs in it and made it internally balanced instead.
