ARP main stud kit....
Old August 4th, 2012, 01:26 PM
Stevec's Avatar
Just got a ARP main stud kit. If I decide to use Main straps on this build will I be able to use this stud kit or do I need to get a different stud kit?
Thanks!
Stevec is offline
Old August 4th, 2012, 05:17 PM
cutlassefi's Avatar
You can use that one. You'll be taking .250 or so off the caps and those studs are longer than stock anyway.
Just take the minimum needed off the caps in order to use the studs.
cutlassefi is online now
Old August 4th, 2012, 05:37 PM
TripDeuces's Avatar
Good call on that Cutlassfi. Use as much cap as you can.
TripDeuces is offline
Old August 4th, 2012, 06:52 PM
Stevec's Avatar
Will do! Thanks guys!
Stevec is offline
RAMBOW
May 27th, 2017 06:11 AM
EightballZ
March 24th, 2014 05:03 PM
Stevec
March 7th, 2014 04:55 PM
Al2011
April 18th, 2013 10:49 AM
Al2011
April 19th, 2012 10:56 AM
Quick Reply: ARP main stud kit....
