water pump bolt timing cover issue
This problem has been discussed before but I thought I would add to the discussion. The bottom two bolts of the water pump will thread and snug up but if I try to put 10ft pounds of torque they keep turning. They water pump did not leak before and I did not strip the bolts since I was using a torque wrench. What gives? I think I will take a chance to see if it holds. They seem snug and all the other bolts are fiine.
Thoughts?
Thoughts?
The 13 ft lbs should be fine. If you don't have a torque wrench that goes down that small. Then use a ratchet and hold it at the **** not on the handle and tighten using wrist action only that way you won't over tighten
the bolts. easy does it
I read on this forum that you don't have to remove the entire oil pan to put the timing cover off/on. They say just losen the front bolts. This would be great since the oil pan gasket is only 1 month old (composite rubber cork). Hate to take the entire pan off and start over but if that is the correct way to do it then I guess I will. Nothing like doing everything twice.
.Rocket.Man.
June 4th, 2015 02:06 PM
