how to separate the trans from engine?
take off the dust cover at the underside where the engine mates to the transmission. There three bolts the connect the torque convertor to the flexplate. Rotate the engine using a large breaker bar and socket on the crank bolt at the front of the engine to access all three bolts then you can separate the engine from the transmission
thks all for feedback
techcote
December 25th, 2012 01:37 PM
Slammed88
June 9th, 2007 05:27 PM
