Bearings for crankshaft
Old September 10th, 2011, 11:31 AM
Fastbrianman's Avatar
My friends 425 crank has been turned 30 under and is probably going to need to be turned again.
Does anyone make a bearing larger than 30 under the 425?
Thanks,
Brian
Last edited by Fastbrianman; September 11th, 2011 at 08:08 AM. Reason: Fixed it, Thanks
Fastbrianman is offline
Old September 10th, 2011, 10:35 PM
svnt442's Avatar
When oversized bearings are being used it's .030 under, not over. Not sure if you can get bearings like that or not.
svnt442 is offline
Old September 11th, 2011, 08:11 AM
cutlassefi's Avatar
Clevite makes .040's.
cutlassefi is online now
Old September 11th, 2011, 07:22 PM
507OLDS's Avatar
I did a 455 in 2001 with .040 rod bearings.Pretty sure they were Clevites.
507OLDS is offline
d4dave1
April 21st, 2013 05:39 PM
oldzy
Drivetrain/Differentials
September 14th, 2010 05:40 AM
raymondh
August 14th, 2008 04:56 PM
poorpea
July 13th, 2008 06:04 PM
Swed Olds
July 26th, 2007 02:55 PM
Quick Reply: Bearings for crankshaft
