GM discontinuing BB oil indicator tube
Old September 9th, 2011, 12:13 PM
frankr442's Avatar
Did a stocking inquiry on GM's website when I reordered my dipstick tube and noticed that it was tagged "DISCON". THey still show stock in Willow Run MI, but when that's gone, that's it. GM # 401357 fits 400 and 455 A-body from 68-72, maybe more but my olds catalog is at home and I work at a Chevy dealership. P.S. Don't order stick # 419242. Even though it's the original #, they changed the handle to a yellow plastic T-style. (this breaks what used to be a rule with GM, any change=new #) So if you think you'll need one, get one now before they're gone.
frankr442 is offline
Old September 9th, 2011, 10:35 PM
svnt442's Avatar
What is the part number?
svnt442 is offline
Old September 10th, 2011, 06:59 PM
I'm amazed it was still available for this long. After all, it's only been THIRTY FIVE YEARS since the last BBO was built!
joe_padavano is offline
Old September 10th, 2011, 10:26 PM
svnt442's Avatar
Duh. Thanks Joe. I must have been more tired than I thought when I posted that.
svnt442 is offline
Old September 11th, 2011, 05:56 PM
Bill in NC's Avatar
Do you guys know if they will work with headers? Or am I stuck with this lame cheesy chrome dipstick?
Bill in NC is offline
Old September 12th, 2011, 05:52 AM
frankr442's Avatar
401357 tube
That tube will "work" with headers, but since it's designed to lay right against the head , there will be some tension depending on the thickness of the header flange. I had one with my headers but I had to get rude with it when I swapped them for manifolds.
Old September 12th, 2011, 09:04 AM
Chesrown 67 OAI's Avatar
Ya gotta "massage it" (translated "bend it") to where it works good with your headers. It is MUCH easier to install with headers if you cut about 2" of unnecessary length from the BOTTOM of the tube ( that part that sticks down into the pan). Makes it MUCH easier to get it started into the hole in the block!!!
Chesrown 67 OAI is offline
Old September 12th, 2011, 12:05 PM
svnt442's Avatar
Well I just talked to the dealer across from my work and he ordered me up a few. He also said they come in pairs for some reason so I will have some spares.
svnt442 is offline
Old September 12th, 2011, 12:29 PM
stetzie
stetzie's Avatar
GM # 401357 Is it the same # for full size cas.
I have a '71 Royale convertible.
Stetzie
stetzie is offline
Old September 20th, 2011, 04:02 PM
Funkwagon455's Avatar
I finally got confirmation that my stash of fill tubes is enroute (6). I got 'em through GMPartsdirect.com, less than $60 shipped to my door.. If anyone may be interested in the online time saving route.
Funkwagon455 is online now
dingusboy
March 8th, 2014 07:09 AM
1k442
February 6th, 2013 02:16 AM
oldspackrat
December 6th, 2012 02:48 AM
1k442
September 17th, 2012 06:02 PM
Quick Reply: GM discontinuing BB oil indicator tube
