Bolt on 455 parts?
Bolt on 455 parts?
I am looking for some bolt on parts to up my HP on a stock 455 that is only pushing 210 HP. I am a amatuer mechanic so I don't go internal. But I would like to have a little more *** behind this thing considering it is in a 69 442 convertible. Any suggestions would be great.
By the RPM you are running it sounds like there is a 2.56 gear in that car. That can be a limiting factor in the giddy up and go, but not always.
I got my 70 cutlass into the 13's with a 455/th400 and 2.56 gears.
I'm still training myself to have some patience when there is something I need (or want) for my cars. My wife helps me with the training though...
In addition to what Cutlassefi said you might wanna look ino a new cam & roller kit and a new intake. If you go too high on the cam you will need a new torque converter and then you might as well go to a posi traction rear end and something like a 3:73 gear.
Thats about it unless you wanna get into heads and all that other stuff.
you dont need HP. HP is the most deceiving figure in the Oldsmobile lexicon. Torque is the name of the game. Based on your HP number, i assume you have "J" heads. if you have the heads ported you can open the exhaust ports to flow like the old "C" heads. add an intake, and HEI dist, and you will have a very torquey driver. ignore HP numbers. with an olds, HP is overpriced and IMHO overrated.
So torque not HP. This my first olds and first solo project. All good info. I do have E heads and a flame thrower distributor but do need to change the intake and carburator. Those spear to be stock. Thanks for all this info guys. Without this site I would be lost and spending way more than I need to.
there is nothing at all wrong with a q-jet if it works properly. E heads should be fine as well. it should be a stump puller from the sounds of it. if it were me, i'd drive it. enjoy the gas mileage of the 2.56 rear end.
Hey I had a MILD 455 with bone stock J heads in a 70 Cutlass S that I got into the high 13's so don't knock the 2.56's too much.
Dual exhausts and a good performance tune may surprise you!
That Q-Jet can be made to run hard, and still give decent mileage, provided the throttle shafts are in good shape. Appropriate secondary metering rods should also be installed. And adjust the secondary air door.
Make sure that distributor has a decent curve, and you should be good to go.
Hope you've extra allowance for right rear tires!!
Okay, my thoughts are pull the heads and get some work done on them, find out what compression you're running and work the heads to give you a little more. Also buy a smaller gasket (assuming the block hasnt been worked) and that will boost compression too. If you have a stock intake you could maybe buy an Edelbrock Performer and get some more power out of that. These Olds big blocks like things big, lots of carb and lots of cam (more than a typical 454, and as such, more than most will tell you would be good with it) 750 carbs are usually good (im not gonna pitch a brand to you, i dont make commission and carbs are carbs so go with a brand you like). People have their own prefferences but if i were you i would swap the rear for maybe a 3.08. That would definatly put more pep in your step. Yeah sure it will hurt mileage a little but if you were worried about mileage you wouldnt be driving a big block in the first place, at that point its a debate between "terrible" and "pretty terrible" and in my oppinion the pros are way better than the cons. But thats my take so dont take it as gospel.
Oh yeah, and exhaust and headers would be the first place id go, which seems to be the general consensus on this thread so far so thats where id start. couple hundred bucks and you'll see a noticeable performance not to mention it will sound way better.
Good luck
Good luck
72442conv
March 19th, 2012 07:14 AM
